getting the timing belt back on my h23 manuel tensioner swap!!!
Old Mar 23, 2006 | 04:31 AM
h22aseemsgood's Avatar
Default getting the timing belt back on my h23 manuel tensioner swap!!!
Hey u guys i just did a water pump and put the bracket on my h23 manuel tensioner that hold s the tensioner in place, but my question is how do u get the damn timing belt back on is there some type of trick? did u guys start off with the cam gears first or, the tensioner i would like some help it would greatly appreciated
Old Mar 23, 2006 | 07:14 AM
Default Re: getting the timing belt back on my h23 manuel tensioner swap!!! (h22aseemsgood)
ne one????
Old Mar 23, 2006 | 07:36 AM
98TypeSH's Avatar
ok heres the trick.
Pull the tensioner off for the Balancer shaft belt ( put it back on after )
Move the Tbelt tensioner so its like halfway on the shaft.
Get the belt aligned on the cams and the crank and water pump
Grab the belt while its town by the tensioner and lift up with both hands on the belt till you muscle it on the Tbelt tensioner. Then slide the tensioner back into its place and put the balancer shaft belt tensioner back in place.
Old Mar 23, 2006 | 11:34 AM
Default Re: getting the timing belt back on my h23 manuel tensioner swap!!! (98TypeSH)
damn dude it is the hardest thing in the world, ive been trying to hours on end and i cant seem to get anyhting acomplished, so your saying disconnect the tensioner all together basically pull it half way off get the belt on there then push it back on and tighten it down with the 14 mm bolt. and then attach the arm to the tension bracket where the 10 mm bolt is.
SkylineKin
Aug 23, 2009 07:04 PM
kornerk12
Nov 25, 2007 02:03 PM
hyabusa hunter
Feb 17, 2007 07:59 PM
h22aseemsgood
Nov 14, 2006 06:53 PM
bigz187
Jan 17, 2006 04:33 PM
