Inner tie-rod end replacement
For those who have replaced the inner-tie rod ends with aftermarket (oem replacement) units, what did you do about the crimped on retaining tabs that were on the stock ones but not the aftermarket?
I didnt even realize they were there until i took off the old ones, breaking the tabs in the process.
Im planning on using the strongest loc-tite i can find, but i just wanted to see what other people had done.
do you need a special tool to crimp the lock washer onto the tie-rod after its screwd into the steering rack piston?
. . . .i probably could have just pm'd you, i had a feeling you were going to be the only on to reply
For the record, im talking about no. 14 in the picture. slhondaparts sells the tie-rod lock washer seperately, so i hope my local dealer can too.
my question remains, do you need a special tool to crimp this lock washer onto the new tie-rod end?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdReNaLiN »</TD></TR><TR><TD CLASS="quote">I'd like an answer to this too...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdlude »</TD></TR><TR><TD CLASS="quote">The "special tool" is a punch.
lol, thats what i was assuming. i ordered new lock washer rings but they wont be in till this weekend. i was planning on just hammering the sides in with a screwdriver
i'll let you guys know if it DOESNT work
</TD></TR></TABLE>lol, thats what i was assuming. i ordered new lock washer rings but they wont be in till this weekend. i was planning on just hammering the sides in with a screwdriver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax420 »</TD></TR><TR><TD CLASS="quote">do you need a special tool to crimp the lock washer onto the tie-rod after its screwd into the steering rack piston?
all you gotta do is slide it on there, and then tighten...it will set itself
</TD></TR></TABLE>all you gotta do is slide it on there, and then tighten...it will set itself
zanedub
Dec 10, 2015 06:46 PM
zurud
Jul 16, 2008 01:07 PM
coot_er
Nov 22, 2007 07:19 PM
