what a stock gsr "should" run and reaction/total time
Old Mar 23, 2006 | 02:03 AM
magicaltrout's Avatar
Default what a stock gsr "should" run and reaction/total time
"low 15's," yeah i know, i searched. but my question is that when people say that, does it include reaction time? i have never been drag racing before and today i ended up with a 15.7 with a r/t of .8 (i feel slow)... on second thought, would anyone like to clarify on whether the total time includes the time it took for my dumb *** to start letting go of my clutch? my main reason for finding out this stuff is to find out whether i'm a shitty driver (no surprise), or i'm fat. please don't flame. i was never really into drag racing, just decided to give it a try today.
Old Mar 23, 2006 | 04:24 AM
Speed94's Avatar
Default Re: what a stock gsr "should" run and reaction/total time (magicaltrout)
Can't answer what your GSR stock should run...have never run my teg yet. In regards to your second question, was it a 400 tree or a 500 tree. .8 isn't that bad considering it was your first time. How did you shift? ie..powershift, granny shift? I noticed with my other car that when I powershifted, it took some time off my 1/4. As far as you being fat....every 100 lbs you lose or shave off the car, you gain .1 in the 1/4 roughly. So its either Jenny Criag or start tossing crap you don't need in your car when you go to the track. i.e. passenger seat, rear seat, jack, spare tire, etc, etc. The more you go to the track the better you'll be...just keep at it and you'll see improvements
Old Mar 23, 2006 | 05:20 AM
mac_24_seven's Avatar
Default Re: what a stock gsr "should" run and reaction/total time (Speed94)
This is a compilation of GSR time slips from Team Integra.
If I'm not mistaken, your time starts when you move, not when the light turns green.
What that reaction time is measuring is exactly that: How long it takes you to react when the light turns green.
It's all in timing. You have to anticipate the light change, because, like you kinda said, your cars not going to react instantly.. You have to let off the clutch, throttle position has to move.. Lots of lil things that add up.
And, for your first time at the track, that's not too terrible in my book.
Remember, a .500 is perfect reaction time, so only being 3 tenths of a second off isn't bad. Practice!!
Anyway, heres the list.
http://www.team-integra.net/se...D=423
2001 GSR 2 Door
Comptech icebox,
aem pulleys,
comptech exhaust,
dc headers,
skunk 2 im
bilstein shocks h&r springs
wildwood big brake kit
Traction was horrible even with tire pressure at 25psi, launch could have been better temperture was 40ish other wise good run. 1st run i misshifted 4th so hard i never got it in. result of such a slow trap speed. would of most definetly been a 14.5
Reaction Time: .660 60 Foot: 2.326 1/8 Mile: 9.490 1/4 Mile: 14.982 Miles Per Hour: 87.94
2000 GSR 2 Door
First run ever with my GS-R. It was about 77 degrees out and i was running on a full tank of 93 octane.All interior was in the car. I had regular Kuhmo street tires on
Type R short shifter
IceMan Cai
Skunk2 exhaust
Reaction Time: .682 60 Foot: 87.9 1/8 Mile: 10.584 1/4 Mile: 16.123 Miles Per Hour: 88.22
1995 GSR 2 Door
Skunk2 Exhaust
DC 4-2-1 Headers
AEM Cold Air
Skunk2 Coil-Overs
Weight reduction (back seats, trunk carpeting, spare tire and jack, removed)
Reaction Time: .757 60 Foot: 2.409 1/8 Mile: 9.773 1/4 Mile: 14.998 Miles Per Hour: 91.99
1994 GSR 2 Door.
aem cai
2.5 custom thermal exhaust
dc sport 4-2-1 header
skunk 2 ecu
Reaction Time: .309 60 Foot: 2.169 1/8 Mile: 9.274 1/4 Mile: 14.382 Miles Per Hour: 95.62
The gsrguy
1999 GSR 2 Door
Comptech Icebox
K&N drop-in filter
DC Sports short throw shifter
Prothane shift bushings
Removed turn signal (help direct airflow to Icebox intake)
Reaction Time: 0.640 60 Foot: 2.443 1/8 Mile: 10.259 @ 68.95mph 1/4 Mile: 15.923 Miles Per Hour: 86.26
00gsrracer
2000 GSR 2 Door
Reaction Time: .370 60 Foot: 2.405 1/8 Mile: 10.154 1/4 Mile: 15.656 Miles Per Hour: 89.63
gs-Rknight
2001 GSR 2 Door
Temp was 55 degrees, and it was sunny. This time I got was after the burn out box, I did not skip it.
Tires were at 25 Psi
Aem intake
CTR cams
AEM underdrive pullies
Aem FPR and Rail AEM
cam gears (stock setting)
Apexi N1 exhaust01
ITR valve springs and reteiners»
DC 4-2-1 header A
pexi vafc, stock except 4700 vtec
Reaction Time: .404 60 Foot: 2.304 1/8 Mile: 9.637 1/4 Mile: 14.866 Miles Per Hour: 94.53
track1646
2000 GSR 2 Door
This was towards the end of the night. I was running against an all motor 60 something VW bug. Moderate clutch slipage at launch to controll traction launched at 4500. 22psi in my bridgestone potenza re730's. Due to my slightly over used clutch (5th run of the night) i had some slipage into second gear. All in all not a bad run.
CAI
REV valves,
overbored Throtle Body,
Hondata heat shield gasket
Reaction Time: .883 60 Foot: 2.278 1/8 Mile: 9.767@72.42 1/4 Mile: 15.149 Miles Per Hour: 90.88
MikeSarrGSR
1999 GSR 2 Door
yet another run at bith-slow/spin city. conditions were good and I had brand-new es100s. I spun the 1-2 FT shift pretty nice, and the car kept accelerating which was good. I recorded my best time. Nothing else changed but the tires. I went home and recorded a compression test. motor is running well, 260-270 across the row.
Reaction Time: .497 60 Foot: 2.279 1/8 Mile: 9.523 @ 75.84 1/4 Mile: 14.687 Miles Per Hour: 94.60
JustanotherGsR
2000 GSR 2 Door
short ram
high flow cat,
custom 2.5" ex.
full int.
Reaction Time: 0.8987 60 Foot: 2.4591 1/8 Mile: 9.9613 1/4 Mile: 15.3587 Miles Per Hour: 91.17
H2Load
1996 GSR 2 Door
street setup ... front tire at 30 psi
Cat-back Greddy Evo2
17'' wheels / 215-40r174-1
ss Dc sport Header
Cai AEM
Reaction Time: .843 60 Foot: 2.442 1/8 Mile: 10.203 1/4 Mile: 15.703 Miles Per Hour: 90.773
Rentegra
2001 GSR 2 Door
Dropzone springs
Tsudo N1 Catback exhaust
AEM Cold air intake
Reaction Time: 0.262 60 Foot: 2.415 1/8 Mile: 9.991 1/4 Mile: 15.355 Miles Per Hour: 91.76
190
gospeedracer182
1998 GSR 2 Door
custom header
custom intake
custom exhaust
VAFC
Reaction Time: .671 60 Foot: 2.273 1/8 Mile: 9.649 1/4 Mile: 14.824 Miles Per Hour: 92.63
SonicBlueTeg
1998 GSR 2 Door
3-27-02
La County Raceway (2700ft elevation)
wednesday night grudge.
windy & night time. left lane car #195
tires: 28psi, launch: 5000rpm
16" yokohama avid h4 340AA
bored out gsr downpipe
hks drager
k&n cone filter in
ngk spark plug wires
60mm trust bpiping w/16" presilencer16" rims w/street tires
original clutch (80k miles. slipping = no full interior + spare
stock airbox powershifting)
Reaction Time: .618 60 Foot: 2.364 1/8 Mile: n/a 1/4 Mile: 15.977 Miles Per Hour: 86.706
Psycshifter
1995 GSR 2 Door
This was my first run of the night after getting a 15.3 qtr mile a month ago without the AEM CAI. It was a cool november evening at the Silver Dollar Raceway near Macon GA, and my goal since I got the car was to get into the 14s. This was when it happened for the first time.
AEM Cold Air
Open Corner light hole where the air filter is
Skunk 2 Exhaust
DC Sports 4-2-1 Header
Removed all interior behind the 2 front seats as well as the spare tire & jack
Reaction Time: .657 60 Foot: 2.409 1/8 Mile: 9.773 1/4 Mile: 14.998 Miles Per Hour: 91.99
red99teggy
1999 GSR 2 Door
ABOUT 75. REAL HUMID. PRETY RUNN DOWN TIRES
after market clutch
short ram intake
Reaction Time: .9745 60 Foot: 2.7896 1/8 Mile: 10.8655 1/4 Mile: 16.866 Miles Per Hour: 84.52
Hvtecpower
1997 GSR 2 Door
Skunk2 exhaust,
DC 4-2-1 header,
and comptech lowering springs
Reaction Time: .192 60 Foot: 2.390 1/8 Mile: 9.942 1/4 Mile: 15.348 Miles Per Hour: 90.97
Traize
2000 GSR 2 Door
My first time at the track, lots of wheel hop
Comptech SRI
Reaction Time: .262 60 Foot: 2.538 1/8 Mile: 10.654 1/4 Mile: 16.404 Miles Per Hour: 84.83
MrAngry
1994 GSR 2 Door
2nd Track run ever.. great e/t.. however, grinded 3rd hard before the 1/8th for about a full second.. (was against a friend's prelude, he looked over at me and psyched me out, heh).. so that explains the final 1/4 time
Generic Carbon Fiber Short Ram
2.25" Cat-Back (Mandrel Bent) .. to 3" Naxos Muffler ..
ACT StreetLite Flywheel (11.5lb)
195/65/15" Michelins @ 25psi .. 75% tread.
Centerforce Dual Friction Clutch
Reaction Time: .314 60 Foot: 2.532 1/8 Mile: 10.336 1/4 Mile: 16.002 Miles Per Hour: 89.55
Shadowhunter
1995 GSR 2 Door
Track was icing over and very cold out. Was my first time at the track and I only got 4 runs in so I think I did pretty well adjusting from launching on the street to launcing on the track.
AEM CAI
Apexi N1 Catback
Reaction Time: .928 60 Foot: 2.496 1/8 Mile: 10.320 1/4 Mile: 15.880 Miles Per Hour: 87.09
Difh
1996 GSR 2 Door
i took out my backseats, passenger seat, spare tire, and power steering. it was a chilly night.
off-brand short ram intake
Reaction Time: .957 60 Foot: 2.452 1/8 Mile: 9.935 1/4 Mile: 15.272 Miles Per Hour: 91.50
Bdashrad
1997 GSR 2 Door
Late September, Cool weather (high 40's), a little traction problems
AEM Cold Air Intake
195/55R15 Stealth Tires @ 20 psi on the front, 30 on the rear
Skunk2 Adjustable Springs
Tokico Blue's (blown in rear)
Reaction Time: 1.218 60 Foot: 2.459 1/8 Mile: 10.079 1/4 Mile: 15.490 Miles Per Hour: 92.22
hokyplayaGS-R
1998 GSR 2 Door
aem cold air intake
shittest tires ever 195-65-15 matador (who has ever heard of that) 28 psi
Reaction Time: .653 60 Foot: 2.453 1/8 Mile: 10.619 1/4 Mile: 16.353 Miles Per Hour: 88.88
Silver2000GS-R
2000 GSR 2 Door
AEM CAI,
KYB AGX,
Eibach Pro Kit,
Yokohama Avid T4's @35 psi,
full interior
Reaction Time: 0.732 60 Foot: 2.371 1/8 Mile: 9.952 1/4 Mile: 15.403 Miles Per Hour: 91.130
skarotum02
2001 GSR 2 Door
first time ever running my car
AEM short ram intake
DC Sport 4-2-1 header
Reaction Time: .606 60 Foot: 2.601 1/8 Mile: 10.8 1/4 Mile: 16.556 Miles Per Hour: 86.2
HndaCvcRcr
1998 GSR 4 Door
This was my second time out at the track(Orlando Speedworld Dragway in Florida) with this car. Temperature was in the low to mid 70s with very high humidity. Still working on getting better launches. Hopefully things will look up when my motor mount inserts arrive.
Comptech Exhaust
Comptech Ice Box
Denso Iridium Spark Plugs
Energy Suspension Front Sway Bar Bushings
H&R Sport Springs
Koni Yellows (front)
MSD Ignition Wires
Prothane Shifter Bushings
Skunk2 Short Shifter
Skunk2 Front Upper Control Arm
Reaction Time: .450 60 Foot: 2.445 1/8 Mile: 10.003 1/4 Mile: 15.349 Miles Per Hour: 91.04
RoyGS-R
2001 GSR 2 Door
Custom cold air intake
Kamikaze ceramic coated header
Apexi N1 Catback
custom 2 1/2" exhaust
Reaction Time: .528 60 Foot: 2.227 1/8 Mile: 9.641 1/4 Mile: 14.926 Miles Per Hour: 93.04
oregondc2
1994 GSR 2 Door+
Nice 80 degree Valley night. I got about 3 runs in. First run missed third (my stupid nerves) 15.57@91.7 mph. Second run better- 15.50 @90.22 mph. Third run was my all time best. I had a 2.48 60ft and was rewarded with a nice 15.42@88.65 mph. I am VERY pleased with this considering I only have a c
at-back exhaust
ires/plugs.
I don't have an intake yet, but I plan on getting a CAI and 4-1 header at the same time.
Cat-back Exhaust.
MSD Wires.
NGK Plugs.
Mugen F1 Valve Cover.
Skunk2 Coilovers
KYB GR-2 Struts.
Fiber Images CF Hood.
94canadiantegra
1994 GSR 2 Door
AEM cold air intake
Skunk 2 IM
DynoPak clutch kit
DC 4-2-1
NOLOGY HOTWIRES
TYPE R LSD Tranny
AEM fuel rail and fuel press. regulator
Apexi World Sport Muffler
MUGEN style ECU chip
AEM cams gears (adv. timing)
REMOVED A/C drive belt
Bored out throttle body
Gutted rear seats, pass. seat, stereo, spare tire, etc.
13 inch slicks
Bumpinwb
1995 GSR 2 Door
Maxspeed Cat-Back Exhaust
DC 4-1 Ceramic Header
Carsound Hi-flow cat
AEM Cold Air Intake
Tokico Premium Performance Shocks
Eibach Sportline Springs
Reaction Time: .873 60 Foot: 2.322 1/8 Mile: 9.893 1/4 Mile: 15.378 Miles Per Hour: 79.69
TelosHedge
1997 GSR 2 Door
aem cai w/bypass
and k&n filter
dc sports jdm 4-1 type r header
act street and strip clutch kit
yokohama avs es100's in 16s
thermal r&d catback
tokico illumina 5 ways (on all the way stiff)
ngk plugs and wires
16.2 lb wheels
2.5" hiflow cat tanabe springs
removed p/s
Reaction Time: +.036 60 Foot: 2.222 1/8 Mile: 9.681 1/4 Mile: 15.043 Miles Per Hour: 91.43
95drsGSR
1995 GSR 2 Door
perfect night for running, cold air, lots of cars
Reaction Time: .562 60 Foot: n/a 1/8 Mile: 9.42 1/4 Mile: 14.633 Miles Per Hour: 95
primeevil711
1995 GSR 2 Door
this was my socond run of the night at Moroso Motorsports Park in palm beach FL. I launched at about 4500rpm.
Reaction Time: .586 60 Foot: 2.597 1/8 Mile: 10.391 1/4 Mile: 15.85 Miles Per Hour: 89.73
FourDoorGSR
1994 GSR 4 Door
Best Time
R/T .702
60' 2.348
330 6.321
1/8 9.592
MPH 76.43
1/4 14.849
MPH 92.89
'99 JDM Integra Type R Swap
Reaction Time: .702 60 Foot: 2.348 1/8 Mile: 9.592 1/4 Mile: 14.849 Miles Per Hour: 92.89
The Natural
. 1995 GSR 2 Door
Aem Cai Type R design
DC JDM Header
Magnaflow Resonator
Skunk2 IM
2.5 Custom Manderal Bend Exhaust
R1 Motorsports Muffler
Hondata IM gasket
Carsound Hi-Flow Cat
Reaction Time: .729 60 Foot: 2.443 1/8 Mile: 9.816 1/4 Mile: 15.046 Miles Per Hour: 93.675
Mentace
1995 GSR 2 Door
This was my second time at the track, with not very many mods, I wanted to see what my car would do with a less restricted exhaust. So i ran a straight header (stock). I gained .4 sec on my time, and got into the 14's. I was not pleased w/ my traction and had some wheel hop due to my tires having bad camber wear on them. All and all this was my fastest run out of 8.
AEM CAI
exhaust cut off right at the collecter
(stock header)
2.3" drop on progress spings Dunlop sp 901's
Reaction Time: .628 60 Foot: 2.380 1/8 Mile: 9.657 1/4 Mile: 14.912 Miles Per Hour: 93.77
WiggiE
1998 GSR 2 Door
Comptech Icebox
Reaction Time: n/a 60 Foot: 2.373 1/8 Mile: 9.813 1/4 Mile: 15.156 Miles Per Hour: 91.60
That should give you a good idea of what other pples reaction times are
Old Mar 23, 2006 | 05:42 AM
nickG's Avatar
theres no need to worry about your reaction time unless you are bracket racing...
you should be more concerned about your 60' time and getting that down...your ET starts as soon as you start moving
Old Mar 23, 2006 | 06:28 AM
Dave_B's Avatar
My old 96 GS-R, I was running like a 15.3 stock and after a V2 intake and Apexi N1 exhaust I ran the fastest of a 14.7. Mind you I'm in FL so elevation is key. Plus the conditions where just right. Like others have said though, RT has no affect on your ET.
Old Mar 23, 2006 | 07:13 AM
siekhatch's Avatar
Default Re: what a stock gsr "should" run and reaction/total time (mac_24_seven)
Good info!
Old Mar 23, 2006 | 07:25 AM
Uncle Willie's Avatar
Default Re: what a stock gsr "should" run and reaction/total time (siekhatch)
NICE post Mac_24_7. GREAT INFO!!!!
Old Mar 23, 2006 | 07:42 AM
Default Re: what a stock gsr "should" run and reaction/total time (RIP Indian Larry)
Thanks.
Kinda handy to have. Gives you a good idea of what GSR's run w/just bolt on's.
I've got one of dyno's also
Old Mar 23, 2006 | 01:53 PM
thanks for all the info guys, really appreciate it.
here's a picture of my timeslip:
what do you mean by powershifting/granny shifting Speed94? i usually go all the way up to redline and then i shift. i always chirp going into 2nd gear also. is it something i should try to minimize?
btw the car on the right is a saturn. i got worried when i saw him next to me in the beginning... somewhat keeping up.
Old Mar 23, 2006 | 03:19 PM
i2un's Avatar
Your reaction time doesn't affect your total time.
Looking at your timeslip, it seems that a reaction time of 000 would be perfect. So with your .800 you really slept at the tree.
1) Try leaving on the last yellow light and not on the green. By the time your car starts moving the light will have already turned green and you'll be off.
2) Also, try different launching techniques. For me when I was Naturally Aspirated the times didn't start getting good until I learned to launch above 4500 rpms. Find what works best for you.
XplodeTeg
Apr 6, 2007 04:36 PM
jman86
Mar 30, 2006 05:20 PM
sp00led
Jun 25, 2004 09:44 AM
skunkintegra
Jun 1, 2003 10:17 AM
max
Dec 20, 2001 09:09 AM
