slight OT : what is the differance in bwtween p06 & p28??
Old Mar 23, 2006 | 12:31 AM
itr1244's Avatar
Default slight OT : what is the differance in bwtween p06 & p28??
i searched but my searching skillz sucks.. i dont know what i've been missing out on but here's my question
why is p28 more expensive in general? why is one better than another?
thanks
Old Mar 23, 2006 | 01:10 AM
RagingAngel's Avatar
Default Re: slight OT : what is the differance in bwtween p06 & p28?? (itr1244)
P28 is for the 92-95 Civic hatches with a D16Z6 motor which has VteCh....
PO6 is for the same 92-95 hatches but use the D15B7 motor with no VteCh...
and we elitists know that everything with vteCh is better and worth more....
The PO6 ecu can be modified to control vtech tho.
Old Mar 23, 2006 | 01:28 AM
itr1244's Avatar
Default Re: slight OT : what is the differance in bwtween p06 & p28?? (RagingAngel)
oh. ok.. so with p28 on my R .. is just plug and play .. with hardness and stuff
and p03 .. need further modification to fit my R
ok.. thanks
Old Mar 23, 2006 | 05:22 AM
98DC2-ITR's Avatar
The key is you need to look for a particluar board # when looking at the P06 for VTEC conversion. You need to look for a P06 Manual or a P06-A52 automatic. The A52 is the only Auto with the correct board id#. The A51 and A50 are not the correct #. The board # you are looking for is 02D011F0-1500. Most of the 5spd P06 ECU's have this #. To be sure open the case before buying.. I am not sure if any of the other board ID's can be chipped but the one listed above is the easiest by far. It is identical to the P28.. Look at the pics below...
Here is the board ID #:
P06 without VTEC components
P06 without VTEC solenoid diode:
Unchipped area of P06.. Look familiar to P28!
P28 Auto with VTEC components
P28 with VTEC solenoid diode
Hope this helps!!
Old Mar 23, 2006 | 06:47 AM
itr1244's Avatar
Default Re: slight OT : what is the differance in bwtween p06 & p28?? (98DC2-ITR)
good info
Old Mar 23, 2006 | 06:52 AM
splitime's Avatar
For some reason I coulda sworn you could use any p05 or p06. There is just a different conversion process for the board variants. http://www.xenocron.com has kits for the conversions of many different formats.
Old Mar 23, 2006 | 06:34 PM
dc2r_j's Avatar
Default Re: slight OT : what is the differance in bwtween p06 & p28?? (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">why is p28 more expensive in general? why is one better than another?</TD></TR></TABLE>
The p28 is used by alot of people to chip and tune their caR (I have one). You need a jumper harness for OBD2 to OBD1, then you plug and play your chipped p28 and start tuning... hope that gives you another answer
Old Mar 23, 2006 | 10:26 PM
itr1244's Avatar
Default Re: slight OT : what is the differance in bwtween p06 & p28?? (dc2r_j)
i have a p28 socketed ecu too lol
Old Mar 24, 2006 | 06:46 AM
Shawn C's Avatar
In The Garage
you can use any 92-95 civic ecu except for the VX (P07 i think) all 11FO boards, and even the 1720 boards are chippable. i can even chip the JM P30 ECUs (extremely pain in the ***)
Old Mar 31, 2006 | 05:50 AM
infulleffect's Avatar
Default Re: (ShadyEH2)
Good info and here is another good link with more info
http://www.zdyne.com/
Old May 1, 2012 | 04:31 PM
cardinalboy07's Avatar
Old *** thread but found it doing research I got a question can an auto chipped p06 be used in a 5spd car say crx 5spd
Old May 1, 2012 | 04:42 PM
AssPenny's Avatar
google is your friend: http://mycomputerninja.com/~jon/www....utoManual.html
Old May 2, 2012 | 10:41 AM
racebum's Avatar
Originally Posted by AssPenny
good post. i didn't know they were so easy to convert
95exdsmkilla
Jul 26, 2007 10:43 AM
95lscivic
Jun 26, 2007 09:44 PM
turboH22Aakkord
May 13, 2005 11:57 AM
auburnBoy
May 26, 2004 08:32 PM
DC2R714
Sep 6, 2002 02:00 PM
