bushings
hey i was wondering if installing all the suspension bushings is easy? and if theres a how to on it. or if not and it is difficult for a newbie how much does it usually cost to get them all installed?
Its a lot of work definitely. In order to get the bushings out, you have to set them on fire with a torch and burn tem out. Installation reuires an arbor press. A shop would charge quite a bit I believe. At least 4-5 hours of labor if not more you are going to pay.
What you could do instead in remove the suspension pieces that your replacing the bushings on and take them to a machine shop and a mechanic you trust and get them to press out and in your new bushings.
Ali
Ali
DA9_DAD
Apr 23, 2009 12:57 PM
Cryptopsy
Jan 30, 2003 10:38 AM
