***What is the highest comp. ratio for daily driver***
Old Mar 22, 2006 | 10:42 PM
wytechoppin's Avatar
Default ***What is the highest comp. ratio for daily driver***
what im exactly trying to say it that.. this summer coming up im planning to put some cams and pistons in my girl..
well i just wanted to know what is the highest comp. ratio that my gsr with 60k miles can handle as a daily driver.?? i was thinking b16 pistons with ctr cams with supertech spings and retainers??? i was thinking itr's but they are a little less comp... thanks let me know.... if some of yall have this set up already or close.. and will my future setup work ok..
Old Mar 22, 2006 | 10:49 PM
rdblckSV650S's Avatar
Default Re: ***What is the highest comp. ratio for daily driver*** (wytechoppin)
just get some good tuning and you'll be fine.
There was a guy in a magazine running 13:1 compression ratio on his GSR with some toda cams, and that was his daily driver.
You just gotta make sure you don't undercam or overcam the motor.
Old Mar 23, 2006 | 01:49 AM
Reid's Avatar
Global Moderator
Default Re: ***What is the highest comp. ratio for daily driver*** (slvrblckf4i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrblckf4i &raquo;</TD></TR><TR><TD CLASS="quote">There was a guy in a magazine running 13:1 compression ratio on his GSR with some toda cams, and that was his daily driver.</TD></TR></TABLE>
You really can't believe everything you read in magazines. It may be his daily driver, but a lot of cars that are portraited as "daily driven" in magazines are far from it.
Old Mar 23, 2006 | 04:05 AM
loudassVTEC's Avatar
You can go up to 13:1, but in order to stay out of detonation, you have to retard the timing, and that causes a loss of power. YOu'd be better off bumping it up to 11.5:1 compression. That compression would work well with CTR cams, or skunk2 stage 1's. Just make sure its tuned whatever you do.
Old Mar 23, 2006 | 04:19 AM
kulrevon's Avatar
Default Re: ***What is the highest comp. ratio for daily driver*** (loudassVTEC)
I know its not a b series. But I know people that are running h22s with 12:1 and 12.5:1 compression completely fine on daily drivers. Just as long as you have a very very good tune you should be good.
Old Mar 23, 2006 | 05:10 AM
PrinceAli132's Avatar
Default Re: ***What is the highest comp. ratio for daily driver*** (kulrevon)
I've seen 12.5:1 on a DD, but as others have said you need good tunning and make sure you run the right octane.
Ali
Old Mar 23, 2006 | 05:22 AM
tegman85's Avatar
im using the b16's in my ls/vtec, hitting 210psi(i think its probably around 11:1) daily driver for like 3 years, never had prob and with no tune, but in a week im getting tuned with crome
Old Mar 23, 2006 | 01:35 PM
Default Re: (tegman85)
ok thanks yall.. i was think of have 11.8:1 as a daily driver on 93 octane. i was first wanting b16 pistons but i changed my thought to JDM type r's basicly the same but has the anti friction coating.. which is better.... at first my plan where usdm type r piston but a friend has thatt setup on his gsr.. and ran him.. i hung with him which i was dissapointed
tronic
Oct 23, 2008 12:18 PM
06BlackSi #45
Honda Civic (2006 - 2015)
11
Jan 16, 2007 12:32 AM
aziantegger10
Oct 16, 2005 07:36 PM
Wesb18DB8
Jun 22, 2005 08:02 PM
jessevtec
11
Jul 16, 2003 09:27 AM
