Gas and Temp Gauge not working correctly?
Old Mar 22, 2006 | 09:45 PM
foam's Avatar
Default Gas and Temp Gauge not working correctly?
I have a 94 DC4 with a JDM B16A and a GSR Cluster. I got the car with the cluster in it, and when I fill up the tank full, it only goes to about 3/4 full on the gas and when my car is fully warmed up it only goes about 2/5's of the way for temperature. Do you think it's something with my cluster? I might just get a new one.
Old Mar 26, 2006 | 04:06 PM
AllmotorEH2's Avatar
Default Re: Gas and Temp Gauge not working correctly? (foam)
You have a dent in the gas tank. You need to check the fluid in your tranny cause there is a crack in the bottom of the housing. Replace the butt conectors on the map sensor plug and solder those wires. Look into a new chassis harness. Those are the only things I can remember off the top off my head.
fcjohnny
Nov 10, 2009 04:36 PM
dylokjai
Jul 15, 2008 04:35 AM
bigboi_626
Jun 6, 2007 10:27 PM
2-7offsuit
Sep 23, 2005 09:45 AM
Aespooncivic
Jan 29, 2005 10:48 AM
