B16a into 92 cx...wont start!!!!HELP!!!
Old Mar 22, 2006 | 09:15 PM
roadrunner1's Avatar
Default B16a into 92 cx...wont start!!!!HELP!!!
I swapped a b16a into a 92 cx...the car ran fine the first 10 or 15 min i had it out...but when i pulled into my garage to check the lug nuts it shut off itself and wont start now...car just turns over but no spark...any suggestions would be great!!!
thanks,
Old Mar 22, 2006 | 09:33 PM
Redline130's Avatar
Default Re: B16a into 92 cx...wont start!!!!HELP!!! (roadrunner1)
Check the coil first, if it's good, then check the ignitor. What condition are the sparkplugs, wires, rotor, and distributor cap?
Old Mar 22, 2006 | 10:55 PM
nello a.'s Avatar
grounds. blew a fuse(look closely. i've wasted a lot of time and money because i did not look carefully at fuse)
Old Mar 23, 2006 | 05:23 AM
Default Re: (nello a.)
i checked all of the fuses and grounds...none of those...i even pulled the injector pulg off and got a test light and put the needle of the test light on the terminal and the aligator clip on the other one and tried turning it over to see if the light would blink but no blink...so im just gonna pull the dizzy off take it apart and look closely
Old Mar 23, 2006 | 09:05 PM
Default Re: (roadrunner1)
got it fixed it was the coil it was burned...running great now ...thanks for your help...oh yeah if anybody knows anybody who has a header for a b16 let me know
bmxerforlife58
Oct 20, 2013 11:09 AM
JNewman227
May 7, 2013 10:42 PM
seanzy13
Mar 17, 2012 03:06 PM
xthekidx
Feb 28, 2009 02:43 PM
scadams
Mar 19, 2008 01:42 PM
