Go into a crash and don't know was wrong with suspension
I hit the crub in the rain and me n my friends looked under the car and nothing is bent but the toe is WAY off. one of my friends said my spindle is bent but he's not sure...I need help so I don't have to buy the whole thing..
sounds like what happened to me. When i hit a piece of metal, spun out, and hit a curb with the front dside wheel, i bent the steering knuckle. was only about a 400 dollar fix. call greenlight auto - 858-569-1511. These are THE BEST Honda/Acura Mechanics in SD and maybe in So Cal. Talk to Jerry Sample and tell him Jon Barrett sent you. He'll hook you up. For the camber adjustment, go to Truline down the street (much cheaper).
ok. then it sounds like what you did is similar to when my friend spun out in a canyon and hit some rocks. Bent the rear lca and the piece of metal that goes through the bushing in the trailing arm. Again, call greenlight in the morning and they'll have you rollin fine by the evening.
The slightest bend in the LCA can set it off a lot,
and you might not even really notice the bend either.
I can't really say much without seeing anything though.
