AEM EMS 1050 Question.... MAP Sensor Issues
Old Mar 22, 2006 | 06:03 PM
kdawgy2k1's Avatar
Default AEM EMS 1050 Question.... MAP Sensor Issues
Wassup people??? Ive got an AEM EMS with a OBD-0 to OBD-1 Conversion harness... Today I Finaly put power to the car and DL'd a base map for the set up... When the key is in the "ON" position, and the car not even cranking or running the MAP sensor shows -6.49 PSIg???? WTF??? I currently have a GM 3bar hard wired from the factory harness to the sensor it self... So far I have swapped 2 new other sensors, Changed the MAP wizard settings and tried loading it back up and unplugging it... and it stays there... when un plugged it reads 31.11 PSIg???
Any help is more than appreciated...
Old Mar 22, 2006 | 06:11 PM
B18CXr's Avatar
Default Re: AEM EMS 1050 Question.... MAP Sensor Issues (kdawgy2k1)
unless you have had a custom 0-1 harness made...then you are using the incorrect AEM PN for this application, 1050 is the OBDII EMS box
Old Mar 22, 2006 | 07:31 PM
xenocron's Avatar
Default Re: AEM EMS 1050 Question.... MAP Sensor Issues (B18CXr)
You also might have the 5v and signal wires mixed up...
Old Mar 23, 2006 | 10:04 AM
yee SERIOUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">unless you have had a custom 0-1 harness made...then you are using the incorrect AEM PN for this application, 1050 is the OBDII EMS box</TD></TR></TABLE>
that's what i thought......sell that 1050 to me.
but if you got it all plugged up, i'm guessing u got the right model?
adamrich33
Engine Management and Tuning
Mar 14, 2009 07:07 PM
oz`Vtec
Jun 30, 2004 02:01 PM
11psiTurboSI
Apr 18, 2004 08:46 AM
NyQuiL
Sep 18, 2003 07:21 AM
