Upgraded to 90-93 rear disc breaks on the 92-95 HB. Tires are rubbing real bad. Any sugestions??
Old Mar 22, 2006 | 06:00 PM
dem0nk1d's Avatar
Default Upgraded to 90-93 rear disc breaks on the 92-95 HB. Tires are rubbing real bad. Any sugestions??
Upgraded to 90-93 rear disc breaks on the 92-95 HB. Tires are rubbing real bad. Any sugestions?? I am going to go out and by a front and rear camber kit, but when i had the drums on it never rubbed... it's scarry, when that **** hits...
Old Mar 22, 2006 | 06:40 PM
mxpx035's Avatar
Default Re: Upgraded to 90-93 rear disc breaks on the 92-95 HB. Tires are rubbing real bad. Any sugestions
did you replace just the hub or the whole trailing arm?
Old Mar 22, 2006 | 07:16 PM
dem0nk1d's Avatar
Parts being used.
90-93 Integra Trailing Arm
90-93 Integra Toe Arm
92-95 Civic lowercontrol arm.
I was thinking maybe i am suppose to be using the Integra control arm, or i should be using the civic toe arm... what ever... **** scraps hardcore when i hit the slightest bumps...
So i am thinking the camber is out to far on the top. Just ordered a full BLOX camber kit, for the front and back 230.00 shipped.
Old Mar 22, 2006 | 08:18 PM
hatchi's Avatar
why not try to put on the civic toe arm
Old Mar 23, 2006 | 06:58 AM
dazdconfsd's Avatar
Any one else gotten this to work with OEM parts? Just curious because I will soon be helping someone else do this swap.
Old Mar 23, 2006 | 12:25 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">Parts being used.
Your problem. Use Civic upper control arm too
Old Mar 23, 2006 | 04:47 PM
dazdconfsd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Your problem. Use Civic upper control arm too</TD></TR></TABLE>
So basically just use the trailing arm from the Integra? All other suspension stays Civic parts?
Old Mar 23, 2006 | 06:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dazdconfsd &raquo;</TD></TR><TR><TD CLASS="quote">
So basically just use the trailing arm from the Integra? All other suspension stays Civic parts? </TD></TR></TABLE>
Exactly
Old Mar 23, 2006 | 06:14 PM
dazdconfsd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Exactly</TD></TR></TABLE>
Thanks for the info
Old Mar 29, 2006 | 07:18 AM
dem0nk1d's Avatar
BlueIntegraBoy: what do you mean use the upper civic arm? you mean the toe arm, that adjust the rear toe in and out? also i just recved my rear camber kit, i am going to install that soon.
Upper Civic Arm???
Old Mar 29, 2006 | 11:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">BlueIntegraBoy: what do you mean use the upper civic arm? you mean the toe arm, that adjust the rear toe in and out? also i just recved my rear camber kit, i am going to install that soon.
Upper Civic Arm??? </TD></TR></TABLE>
The upper arm being the arm to adjust camber and the toe arm.
#5 & #16/19
Old Mar 29, 2006 | 05:28 PM
dem0nk1d's Avatar
Well i bought a full camber kit front and rear. So the new upper control arm as we will call it, that adjust camber is totaly adjustable. So I will install it and get the car alined. Also I will have to install the front camber kit as well.
jaypanEG6
Aug 26, 2006 08:08 AM
dem0nk1d
10
Mar 18, 2006 05:48 PM
racekar
Suspension & Brakes
22
Feb 2, 2005 05:46 AM
91SIR
Apr 22, 2003 01:56 PM
