integra front end trouble.
Old Mar 22, 2006 | 05:48 PM
DarkDC2's Avatar
Default integra front end trouble.
I have just put on my radiator suport and fenders, but the hood would not fit (Hood is very wide). Do you guys have any idea, what is wrong?
Dforce's Avatar
That's what she said!
Default Re: integra front end trouble. (DarkDC2)
pics
Old Mar 22, 2006 | 06:09 PM
integra3586's Avatar
Default Re: integra front end trouble. (Dforce)
ttiwwop
Old Mar 22, 2006 | 07:24 PM
morocco's Avatar
Default Re: integra front end trouble. (B18B-SC)
I had a similar problem, the fenders and hood arent aligned properly. Since you took the fenders off, they are the big problem; loosen all the nuts holding it and (slowly) lower the hood. It could be a two man job (you need to pull the fenders out (not off) and place them further out, so someone needs to pull the fenders out, then lower the hood and readjust until everything fits nice). Basically, the alignment and placement of your front end sheetmetal is off. Work from the fenders to the hood, making sure the fender/door gaps are nice and tight, then work to the hood and do the same thing until everythings nice nice . Sometimes this takes 10 minutes, sometimes a good day, so be prepared. Some tips; when the alignment is close, tighten the bolts and work the other side (that way the closer you get to perfectly aligning everything up, the less effort it takes to finish the job), also, if you're unsure of how much space should be between panels, use a paint stirrer and if its about as small as the stirrer's width, its good. Good luck, hope this helps!
Old Mar 23, 2006 | 11:37 AM
DarkDC2's Avatar
Default Re: integra front end trouble. (morocco)
I don't know, my hood seems big and I can't bolt them onto the car. Its like sticking out.
Old Mar 23, 2006 | 11:40 AM
.brian.'s Avatar
do you have the right hood? the correct fenders? are they OEM?
Old Mar 24, 2006 | 04:41 PM
DarkDC2's Avatar
Default Re: integra front end trouble. (.brian.)
yeah, I bought at a place where they took it out from a jdm integra.
Old Mar 24, 2006 | 04:51 PM
MenaceL.A.671's Avatar
did u have any past or recent accident with your car?
thats really wierd.. should fit... and make sure the hood is a ITR hood not a DA or accord hoood...
GR_DC2's Avatar
that hood can't be an integra hood, our washer nozzles are just below the windshield, not on the hood.
Old Mar 24, 2006 | 04:53 PM
Default Re: integra front end trouble. (MenaceL.A.671)
i notice your hood has windshield washers... integras windshield washers are normally not on the hoood...
Old Mar 24, 2006 | 05:31 PM
Uncle Willie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aznspeedracer &raquo;</TD></TR><TR><TD CLASS="quote">that hood can't be an integra hood, our washer nozzles are just below the windshield, not on the hood. </TD></TR></TABLE>
Old Mar 24, 2006 | 06:32 PM
spoolinfool's Avatar
Yeah , for sure that isnt a jdm integra hood.It looks like a DA integra hood.
Old Mar 24, 2006 | 07:12 PM
DynastyRacer22's Avatar
Default Re: integra front end trouble. (spoolinfool)
yup ur windshield nozzle is right under neath the windshield whiper on the car not on the hood..but yeah before u bolt everything tight just loosen it up a lil and check if everything is lined up once its lined up just tighten it like the guy above said
Old Mar 24, 2006 | 07:15 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinfool &raquo;</TD></TR><TR><TD CLASS="quote">Yeah , for sure that isnt a jdm integra hood.It looks like a DA integra hood.</TD></TR></TABLE>
Its definetly not a DA hood. DA hoods have the washer nozzles underneath too. That doesnt look like it goes to any integra.
Old Mar 24, 2006 | 08:48 PM
RHDintegXsi's Avatar
Default Re: integra front end trouble. (mike9571)
its def not a dc hood..usdm or jdm..im starting to think its not even a da hood..it looks more like a 94-97 accord hood maybe
Old Mar 25, 2006 | 05:22 AM
ajantics's Avatar
Default Re: (Aznspeedracer)
I don't know what type of hood that is, but that is not a JDM integra hood/ or usdm integra hood either. There should be the factory sticker on the underside of the hood telling you the chasis code for what that hood belongs to, unless someone took it off. If not, can you take a pic of the hood from the top? That way we might be able to tell you what car the hood came from!
Old Mar 25, 2006 | 07:06 AM
TURBODC4TEG's Avatar
Default Re: (ajantics)
dude u have a DA hood on a DC body won't work duh
Old Mar 25, 2006 | 07:23 AM
shyboy817's Avatar
They already stated that DA also have washer nozzle underneath the hood, not on the hood.
Old Mar 25, 2006 | 07:25 AM
SuperHonDad's Avatar
Default Re: (TURBODC4TEG)
MIKE is right The DA hood also has the nozzles underneth. Let us see the top weel figure it out. It is kind of odd that it has no Code stiker if it's OEM.
Old Mar 25, 2006 | 04:48 PM
mike9571's Avatar
Default Re: (SuperHonDad)
Measure the hood and than ask for some measurements of a hood that is the right one.
This will clear up everything becuase clearly someone screwed you over
tinyscivic
Paint and Body
Apr 23, 2010 08:12 PM
1sickef9
Apr 13, 2010 09:25 PM
Ludeist
Sep 16, 2007 05:25 PM
xpsonic
11
Aug 6, 2002 09:15 PM
