94 Accord, Front Lower Ball Joint Removal.
Old Mar 22, 2006 | 05:26 PM
s13_240sx_92's Avatar
Default 94 Accord, Front Lower Ball Joint Removal.
I want to replace the lower ball joint on a 94 Accord. The boot is torn and was making the car suspension squeeky, so I figure I should replace the joint being the grease wasn't all in there.
So, I need to remove the ball joint from the knuckle. Do I need a Press for this? Or a vice/socket trick? or can I just tap it out with a hammer? I've replaced one on a Civic earlier and Just tapped it out with a hammer, I think I heated the knuckle with a torch too.
Anyone able just to knock it out of the knuckle with just a hammer?
And I'm not talking about removing the joint from the LCA.
Thanks!
Old Mar 23, 2006 | 02:13 PM
Default Re: 94 Accord, Front Lower Ball Joint Removal. (s13_240sx_92)
bumps
Old Mar 23, 2006 | 07:08 PM
devilpuppy's Avatar
why not just change the whole axle...it will be easier i think
but otherwise, i think you can just tap it out with a hammer
portugueboy10
Jan 18, 2013 08:20 PM
HONDAPARTSMANMIKE
17
Sep 29, 2010 04:14 PM
Digitalsmoke
Aug 14, 2009 08:57 PM
Dasavior
Jun 6, 2004 07:29 AM
tom991
Mar 30, 2004 04:40 AM
