How do u elimanate Emissions?
Old Mar 22, 2006 | 04:49 PM
vtec25's Avatar
Default How do u elimanate Emissions?
How do i go by this? i got a 94 ex wit a b18 in it. What do i unplug, plug up, disconnect, etc.
Old Mar 22, 2006 | 04:58 PM
M2nR's Avatar
Default Re: How do u elimanate Emissions? (vtec25)
Get a Power Wheels
Old Mar 22, 2006 | 05:15 PM
Syndacate's Avatar
a catalytic converter?
Old Mar 22, 2006 | 05:17 PM
derspi's Avatar
When you figure out how to "eliminate emissions", call up any car manufacturer, I'm sure they'd like to know how you did it. Oh, they'll also make you an instant millionaire too.
If you're asking how to reduce emissions as much as possible then I would first suggest doing all the necessary tuneup items such as oil change, air filter, sparkplugs, rotor & cap, fuel filter as well as checking all fluids and timing.
Old Mar 22, 2006 | 05:18 PM
Syndacate's Avatar
I'm not trying to be an *******, u g2 be more broader though...what do u mean "eliminate emissions???"
You will always have emissions, if you don't have any emissions then your engine wouldn't complete the 4th stroke meaning it wouldn't have done the 3rd stroke meaning it couldn't have ran....
if you're askign how to lower emissions? did ur car fail emissions test? What is it? Any internal combusion engine has emissions, even hybrids
ur catalytic converter lowers them
Old Mar 22, 2006 | 05:28 PM
one bad dx's Avatar
Default Re: (Syndacate)
Um, you dont. Sorry their's no way around it.
Get a good catalytic converter to lower them.
Old Mar 22, 2006 | 06:28 PM
junkyardd16z6's Avatar
I have a 99 GSR swap in a 94 DX (needs coolant line hooked up, vaccume lines hooked up and wired up.), but I dont have a evap purge control solenoid valve. Does any body know how to bypass that? so I can run the car without it. Im goin to use a chipped P28. Thanks
Old Mar 22, 2006 | 07:33 PM
De_tour's Avatar
well over here, in washington, just register your car outside the 2 major countys where they dont do a smog test for your car, and u dont have to have any sensor or cat for that matter
Old Mar 22, 2006 | 07:34 PM
De_tour's Avatar
Default Re: How do u elimanate Emissions? (wspcivic)
im soo read that wrong hahahaah
California98Civ
Southern California
Sep 1, 2014 09:54 AM
ANNiHiLATORS
24
Aug 25, 2012 09:16 AM
SI_Ro
Dec 21, 2011 10:36 AM
Juans_MX3
May 7, 2010 11:34 AM
94GSRRacer2
Apr 23, 2002 03:33 PM
