For those of you owning B20Vtec's, I have a question????Please help???
Old Mar 22, 2006 | 04:39 PM
sleepy_hatch's Avatar
Default For those of you owning B20Vtec's, I have a question????Please help???
I'm doing the B20B Vtec conversion. I'm putting a GSR head on the block. I was wonder what ECU should I run for this application???Thanks for the help
Old Mar 22, 2006 | 07:54 PM
brokeHonda's Avatar
Default Re: For those of you owning B20Vtec's, I have a question????Please help??? (The Mailman)
Chipped P28 with your choice of Operations (Hondata, Crome, ...)
Old Mar 22, 2006 | 08:37 PM
Default Re: For those of you owning B20Vtec's, I have a question????Please help??? (brokeHonda)
Thanks for the info.
Old Mar 23, 2006 | 04:22 PM
hybrid92b20's Avatar
i'm running a crome pro chipped p28 on my si head/b20b, thanx to import jedi
Old Mar 24, 2006 | 10:59 PM
Default Re: For those of you owning B20Vtec's, I have a question????Please help??? (hybrid92b20)
Thanks, I also have another question. Do I use the B20 head bolts or the gsr head bolts when I put it back together. Also how many ft lbs of torque is required for the b20 head bolts to if I use them to put it back together.
Old Mar 25, 2006 | 07:32 AM
jdmitr's Avatar
Use the gsr head bolts. I would get a ARP GSR head stud kit.
Old Mar 25, 2006 | 10:57 AM
brokeHonda's Avatar
Default Re: For those of you owning B20Vtec's, I have a question????Please help??? (jdmitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Mailman &raquo;</TD></TR><TR><TD CLASS="quote"> Also how many ft lbs of torque is required for the b20 head bolts to if I use them to put it back together. </TD></TR></TABLE>
62 ft lbs in sequence
Old Mar 25, 2006 | 11:12 PM
7mile's Avatar
Are you using a catch can ? jw...
clayton bigsby
Oct 19, 2006 11:34 PM
existanzcivicb20
Mar 30, 2006 01:13 PM
existanzcivicb20
Mar 30, 2006 12:24 PM
existanzcivicb20
Mar 30, 2006 11:40 AM
