Weird Noise
Old Mar 22, 2006 | 02:14 PM
Shake and Bake's Avatar
Default Weird Noise
Whenever i go up a drivway ramp on an angle i hear this loud pop, like the spring is doing somthing. But when i go up the drivway ramp perfectly straight there is no noise. I have omni street full coilovers. Does anyone elses car do this?
Old Mar 22, 2006 | 02:40 PM
Bump
Old Mar 22, 2006 | 04:53 PM
Go_Race_Your_Self's Avatar
Two Piece
Default Re: (AllstockSIke)
try this.....www.backmotorsports.com and find dans yahoo address...he could help you
Old Mar 22, 2006 | 05:32 PM
one bad dx's Avatar
Default Re: (Go_Race_Your_Self)
sounds like your shock tower hat is out of whack.
Old Mar 22, 2006 | 05:35 PM
poison's Avatar
Default Re: Weird Noise (AllstockSIke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllstockSIke &raquo;</TD></TR><TR><TD CLASS="quote">Whenever i go up a drivway ramp on an angle i hear this loud pop, like the spring is doing somthing. But when i go up the drivway ramp perfectly straight there is no noise. I have omni street full coilovers. Does anyone elses car do this?</TD></TR></TABLE>
Good question, cuz mine does this as well. And I have Omni Sports.
I'm not exactly sure what it is, but after numerous times of looking at it, everything looks fine.
Good point though.
Old Mar 22, 2006 | 06:05 PM
TurboLaxx's Avatar
Default Re: Weird Noise (poison)
Mine does this too. Its from the coilovers. Your wheel is falling so low that the spring isnt being compressed anymore. It actually just falls loose around the shock. When it's recompressed the lip of the spring is catching on the giant lower height adjusting nut and then pops back into place.
In this picture see how the gold nut is tapered...it does this so if the spring catches on the inside of it, the taper throws it back onto the flat part. That's what that big klunk noise is.
Old Mar 22, 2006 | 07:59 PM
Thanks, so its no biggie than?
Old Mar 22, 2006 | 08:05 PM
95b16ej1's Avatar
Default Re: Weird Noise (TurboLaxx)
naw I dont think so the omnis are pre loaded and there is only abot 22 mm of travel in the shaft itself. so you can "pick up a wheel" on drop offs and curbs like that when you do this there is no loss of tension on the spring to the body of the strut
I would check all bolts and axles too
Old Mar 23, 2006 | 08:05 PM
TurboLaxx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllstockSIke &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, so its no biggie than?</TD></TR></TABLE>
I wouldnt worry about it.
Old Mar 23, 2006 | 09:15 PM
Contender25
Guest
Posts: n/a
Mine and and my buddys car do this from having coil overs, it's a part of life, eh.
Old Mar 23, 2006 | 10:31 PM
95b16ej1's Avatar
Default Re: (Contender25)
does being a noob make my posts invisible?
these arent like the 49$ ricer coilovers you buy on EBAY!!!!!
Old Mar 24, 2006 | 06:19 PM
Contender25
Guest
Posts: n/a
Doesn't matter, if you expect to turn you're car into a race car then you give up these things when you replace the stock oem honda shocks and springs. You think just because you buy the same thing thats more expensive it's not gonna do that?, it does the same thing, just built better then the cheap ones.
Old Mar 25, 2006 | 07:43 AM
Default Re: (95b16ej1)
NO newbee they arnt "ricer" coilovers. Ok thanx ill just deal with it, it doesnt bother me that much i just thought i may have put somthing on wrong.
Old Mar 25, 2006 | 08:48 PM
Contender25
Guest
Posts: n/a
Define ricer coilovers, hell define coilovers them self...
A.C. Slater
Suspension & Brakes
Aug 18, 2010 02:41 PM
solesthatgo
Suspension & Brakes
Nov 5, 2009 02:39 PM
bay_DA
Oct 9, 2006 06:52 PM
alwaysoverkill
Suspension & Brakes
Mar 21, 2006 10:44 AM
