OOPS!!! question on fixing air compressor!!!
Old Mar 22, 2006 | 09:59 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default OOPS!!! question on fixing air compressor!!!
I've got a 30gallon kobalt air compressor but broke off the air regulator stem.
It broke off right inside the outlet on the tank and they've got some sort of uber-sealant on it. I've been trying and trying with an easyout and cant get it to budge...I just keep tearing up my tools. Oh, and the damage isnt warrantiable since due to how it happened.
anyway, can I just drill out and retap the threads and be done with it?? I'd go ahead and just do it but I dont know how the filings that I know will get into the tank will act?? Will they just stay and behave themselves at the bottom of the tank or when pressure is built up and I use a tool will they fly up and clog up ****??
Old Mar 22, 2006 | 10:11 AM
NJcoupe's Avatar
same thing happened to me.
heat it up then use easy out.
Old Mar 22, 2006 | 11:24 AM
stackz's Avatar
Community Builder
Default Re: (idriveacoupe.)
sweet man, didnt even think of that for some reason. worked like a charm! now I wonder if the teflon tape I've got will do the trick since I dont have any of that sealer?
Old Mar 22, 2006 | 01:22 PM
nfn15037's Avatar
Default Re: (stackz)
Teflon tape will work fine on pipe threads. It is better to use normal pipe sealant, but the tape crap works. Just be aware of the direction you are wrapping and don't go crazy with tons of it.
Old Mar 22, 2006 | 02:38 PM
NJcoupe's Avatar
Default Re: (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">Teflon tape will work fine on pipe threads. It is better to use normal pipe sealant, but the tape crap works. Just be aware of the direction you are wrapping and don't go crazy with tons of it.</TD></TR></TABLE>
sykikchimp
12
Jun 9, 2010 04:03 AM
Propulsion
Welding / Fabrication
Nov 16, 2005 06:14 AM
cityofcaterpillars
Aug 23, 2004 11:06 AM
AzntaggeR
Aug 6, 2003 09:29 AM
43MA
Jan 16, 2003 05:02 PM
