B16A1 wiring question
I'm wiring the b16a1 distributor for my brother's 92 civic cx's wiring harness, the civic's harness has the following colors
blue with green stripe and blue with yellow stripe (both wires wrapped in same loom)
orange with blue stripe and white with blue stripe (both in same loom)
then solid orange wire and a solid white wire (in same loom)
lastly a yellow with green stripe by itself
the distributor's main (large) plug all seems to be the same colors with the exception of a single white wire, which is left to mate with the yellow with green stripe wire from teh 92's wiring harness. Is this correct, following the color coding, except putting the solid white wire with the yellow with green striped wire? I've tried searching on this, but have come up with 0 results on this board and on others. Any help is greatly appreciated. We just need to get the car running now, will swap out to a obd1 distributor when his budget allows.
Thanks,
Richie
Thanks,
Richie
I'm still searching on this, looks as if that yellow with green striped wire coming out of the car's harness is going to actually go to the vtec solenoid. So i'm now just left with the top white wire coming off the b16a1's distributor plug. I can take a pic of the wire in question if this will help anyone.
Richie
Richie
hondaZvic
Apr 22, 2004 12:51 PM
