Work Emotion Wheels for S2000
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut »</TD></TR><TR><TD CLASS="quote">Are you getting 17x7 on all four corners?</TD></TR></TABLE>
Hope not, because you'd be stuck with 225 tires.
for the emotions....
size one
17x7 +42 205 tire
17x8 +47 245 tire
size two
17x7 +47 215 tire (maybe 225 tire)
17x8 +47 245 tire
size one
17x7 +42 205 tire
17x8 +47 245 tire
size two
17x8 +47 245 tire
17x7 47 ft 215 45
17x8 47 rr 245 40
i was running 255 40 rr in this pic, but i was getting a little rub in the rear on larger dips in the road....
I now I stupid for asking but I'm not sure if I understand offset that well. What exactly does offset really mean to a rim? What is the differents between lower and higher number offset?
I was thinking maybe 17x7 Front 17x8 Rear.
offset means how far the outer circle is pushed in/out in relation to where ur wheels bolt at. i forget if negative means it sticks in/out more.
something that someone might want to add more light to is that if you push your wheels too far out, how much or how little would it affect the car's handling characteristics.
those deepdish wheels that u see, usually have a huge negative or positive offset. look around on tire rack or google.
Do they come in anything bigger than 8"? I haven't looked into Work's, but most of the others I'm looking at (Volk, Advan, etc) come at least 8.5" or wider.
BTW, the lower the number, the farther it sticks out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf »</TD></TR><TR><TD CLASS="quote">^ those are 16's.... 16x7 +36 i believe.... you won't find 16's anymore.... only 17's and 18's that'll fit our cars..</TD></TR></TABLE>
im pretty sure the forged emotions were a +35
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonk20 »</TD></TR><TR><TD CLASS="quote">What is the second wheel? Volk? </TD></TR></TABLE>
they are the new emotions...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RWD_Honder »</TD></TR><TR><TD CLASS="quote">i know that the s2000 has crazy high offsets stock.
you might wanna stick around 50+ rear, 45+ front AT LEAST.
just my .02 tho</TD></TR></TABLE>
depends on how wide the wheels are.
xkrntamax
Honda Civic (2006 - 2015)
May 3, 2010 06:16 PM
