which bearing for a d15b
Old Mar 21, 2006 | 11:57 PM
lemon_juice's Avatar
Default which bearing for a d15b
im planing to to the PMS (gx piston swap) to my d15b, and while i have her cracked open ill be replacing most things like head gasket, oil pan gasket, piston and rings, and the crank end bearing.
so today i go into the honda dealership to order the bearing and they tell me there is different colors. i know ill be using bearing from a d16z6 but im not sure exactly which color or part number.
Old Mar 22, 2006 | 12:01 AM
BlueIntegraBoy's Avatar
Default Re: which bearing for a d15b (lemon_juice)
13032-PH3-S20 BEARING A SET, MAIN (BLUE) (TAIHO)
13033-PH3-S10 BEARING B SET, MAIN (BLACK) (DAIDO)
13033-PH3-S20 BEARING B SET, MAIN (BLACK) (TAIHO)
13034-PH3-S20 BEARING C SET, MAIN (BROWN) (TAIHO)
13035-PH3-S10 BEARING D SET, MAIN (GREEN) (DAIDO)
13035-PH3-S20 BEARING D SET, MAIN (GREEN) (TAIHO)
13036-PH3-S10 BEARING E SET, MAIN (YELLOW) (DAIDO)
13036-PH3-S20 BEARING E SET, MAIN (YELLOW) (TAIHO)
13037-PH3-S20 BEARING F SET, MAIN (PINK) (TAIHO)
13038-PH3-S20 BEARING G SET, MAIN (RED) (TAIHO)
CKnight90
Aug 13, 2015 03:56 PM
turbohatch96y7
Mar 9, 2013 03:10 PM
h224thgensedan
Mar 8, 2008 12:55 PM
auto moto
May 15, 2005 07:01 PM
Mad Cow Disease
May 31, 2004 09:08 AM
