Whats the name of this bolt?
I just changed struts recently and while changing, the bolt that connects the bottom of the strut to the control arm breaks. Does anyone know the name of the bolt? I couldn't find it at the hardware store and so I just put in a standard bolt from the hardware but it doesn't have the bumps along the side like the one that broke. The other problem is that now the wheel cambers out, is this the result from having the wrong bolt in place? or should I go get a alignment? thanks guys.
yeahey are just lca bolts i went to a junk yard and got some to hold me over untill i got new ones
btw lca bolts are standard so if you can find one off a crx or a older civic that will work too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dr-Si »</TD></TR><TR><TD CLASS="quote"> I just changed struts recently and while changing, the bolt that connects the bottom of the strut to the control arm breaks. Does anyone know the name of the bolt? I couldn't find it at the hardware store and so I just put in a standard bolt from the hardware but it doesn't have the bumps along the side like the one that broke. The other problem is that now the wheel cambers out, is this the result from having the wrong bolt in place? or should I go get a alignment? thanks guys.</TD></TR></TABLE>
are you ready to risk your life/lives of others/damage to your car by putting in a "standard bolt"?
BoostinEJ1
41
Apr 16, 2006 01:18 PM
racekar
16
Jun 21, 2004 09:07 AM
