Skunk2 B18C5 Swap
I'm planning on buying a modified engine very soon with the following setup from an ITR to my 99 Civic Si:
- USDM 98 B18C5 w/ OEM LSD Tranny and 4.7 FD
- Skunk2 Stage 3 Camshafts, Cam Gears and Valve Springs
- Apex Power FC ECU
- RC310 Injectors and AEM Fuel Rail
- Exedy Clutch
- Stock ITR Header and Air Intake
Is this too much engine for a daily driver? I plan on driving with this setup for 100km/day and wondering if itll be reliable and streetable.
The ECU is tuned for an ITR with the listed setup plus AEM CAI, Hytech header and Mugen exhaust. Will I need to tune the ECU again if I use stock USDM ITR air intake, header and Si exhaust? Will I get problems if I dont tune the ECU with my stock setup?
Also, when I go aftermarket which intake do I buy; ITR or Si? Can I use an ITR exhaust system and motor mounts on my Si?
Thanks for your time.
- Apex Power FC ECU
- Exedy Clutch
the cams came with the engine. id also like to add that it has a ported head, trottle body and intake manifold. the block is also balanced and has flycut pistons.
anyone with a similar setup use it as their daily driver? how do you like it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinsanity1379 »</TD></TR><TR><TD CLASS="quote">the cams came with the engine. id also like to add that it has a ported head, trottle body and intake manifold. the block is also balanced and has flycut pistons.
anyone with a similar setup use it as their daily driver? how do you like it?</TD></TR></TABLE>sounds like fun to me
Dom_GsR
Aug 11, 2004 10:20 AM
