Suspension & Brakes Theory, alignment, spring rates....
Need a camber caster kit
Old Mar 21, 2006 | 02:21 PM
tial-eg's Avatar
Default Need a camber caster kit
I have a 94 Honda civic hb.... I need a camber caster kit.... I have an alignment machine so I know my camber caster is off.... yes I work at a shop but for some reason I can not find a kit for my car... sad.
Old Mar 21, 2006 | 10:22 PM
tial-eg's Avatar
Default Re: Need a camber caster kit (tial-eg)
bump
Old Mar 22, 2006 | 07:57 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tial-eg &raquo;</TD></TR><TR><TD CLASS="quote">I have a 94 Honda civic hb.... I need a camber caster kit.... I have an alignment machine so I know my camber caster is off.... yes I work at a shop but for some reason I can not find a kit for my car... sad. </TD></TR></TABLE>
What are your numbers? If your caster is off, something is probably bent.
Old Mar 22, 2006 | 04:39 PM
tial-eg's Avatar
Default Re: Need a camber caster kit (AutoXer)
my car is lowerd like... 1.5in all around on 16in enkiens t1 rallys... that is why my camber and caster... and it is like 1 dagree all around is off....
Old Mar 22, 2006 | 04:48 PM
Tyson's Avatar
why do you need to change your camber and caster?
just keep your toe in spec.
Old Mar 22, 2006 | 06:05 PM
tial-eg's Avatar
Default Re: Need a camber caster kit (Tyson)
if i do not ajust the camber caster my tire will where bad.... and when you rune proxes.. t1s 215 40 zr16 they get pricy....
Old Mar 22, 2006 | 11:40 PM
Tyson's Avatar
if you make sure your toe is aligned, your tires will wear fine.
danny_civic97
Suspension & Brakes
May 5, 2007 03:46 PM
4drteg916
Suspension & Brakes
Feb 22, 2007 12:07 PM
guero2craze
Suspension & Brakes
Feb 22, 2007 09:53 AM
vbspec
Oct 8, 2003 04:52 AM
KraZyCHOWMEIN
Dec 19, 2001 07:58 PM
