Insight Antenna Pix
Well after having crappy reception from my S2000 antenna (kit purcahsed from RStoR), I tried the Honda Insight Antenna.
the antenna is 14 bucks from http://www.handa-accessories.com (i think that's the site)
anyway, here it is
note: the base is smaller than the s2k, but it actualy seals so there is no hole for water to leak thru.
[Modified by Toda Party, 2:04 PM 4/2/2002]
[Modified by Toda Party, 2:22 PM 4/2/2002]
anyway, here it is
anyway, here it is
anyway, here it is
[Modified by CPR, 5:05 PM 4/2/2002]
so the reception is a lot better?
hmm.. is S2K owner have the same bad reception like our conversion??
[Modified by CPR, 5:10 PM 4/2/2002]
h,, what'd i do wrong w/ the picture?
anyways, yeah the insight antenna makes a WORLD of difference (at least for me)
plus, i had wrapped the base with like 20 feet of copper wire too so i was disappointed in the s2000 antenna's reception.
u can just swap em, RStoR's kit works with either
from what i can see from the kit, all u would need is to make sure you use the stock mount(black thing) where the antenna rises from. otherwise it should work
however, i can't remember where the civic antenna is. mine was easy to get to but if the antenna is in the fender or something, then i dunno how easy it is to pull off the fender and such
- reception is almost as good as stock, huge improvement over the s2000. no more rising and falling antenna R0x0rz
[Modified by Toda Party, 4:37 PM 4/2/2002]
just make a switch, mad reception when you want it, retracted antenna when you don't....and it'll cost you around 5 bucks and a little work. our site has info, of course
right his kit, and the stock mount where the extending/retracting thing came out of (the black piece)
direct fit, looks nice, and better reception (cheaper too 20 vs 14 bucks heh)
