dx tranny and ex tranny different right?
Old Mar 21, 2006 | 12:07 PM
flatblakd15vt's Avatar
Default dx tranny and ex tranny different right?
i have a dx tranny now with a jdm d 15 and im wondering if its worth it to change to an ex tranny (besides the fact its not a b-series) because of the gearing.
Old Mar 21, 2006 | 12:08 PM
zacatkings's Avatar
Default Re: dx tranny and ex tranny different right? (flatblakd15vt)
yes gearing difference is worth it specially with d series
Old Mar 21, 2006 | 12:11 PM
snatch's Avatar
Default Re: dx tranny and ex tranny different right? (zacatkings)
Most certainly. Change it.
Old Mar 21, 2006 | 12:28 PM
NazVil86's Avatar
Default Re: dx tranny and ex tranny different right? (******)
yeah man, the dx gears are too freakin long. we did a mini me swap and ran it with our dx tranny and hit a best of a 16.8, did a lil searching around this board and found out that ex/si trannys are a whole lot better and can get a mini me hatch into the low to mid 15s, we just put ours in with a stage3 clutch, really big difference, hope that helps.
Old Mar 21, 2006 | 12:29 PM
NazVil86's Avatar
Default Re: dx tranny and ex tranny different right? (Carnage86)
also so u dont get screwed by some guy, the code on the tranny is B00, or A00...i think a00 is the dx and b00 is the ex...or are they backwards lol sorry, i have bad memory.
Old Mar 21, 2006 | 01:57 PM
HondaEJ7's Avatar
P20 A000 = DX
P20 B000= EX
i had an HX tranny, i swapped to EX, and i couldnt be happier. the gearing is alot better, go with the EX for sure.
Old Mar 21, 2006 | 02:04 PM
schardbody's Avatar
haha everyones wrong.... S20 A000 = cx/vx/dx/lx
S20 B000 = ex/si
Old Mar 21, 2006 | 02:57 PM
HondaEJ7's Avatar
um no...
92-95 tranny codes are:
P20/A000 is for DX/CX/VX
P20/B000 is for EX/Si
so actually, YOU are wrong. dont believe me?
http://home.cinci.rr.com/mistab0ne/tranny.html
s20 is the casting code. there is a difference of bearing size in the ex/si tranny vs. the dx/cx/lx tranny.
The different casting to make up for this size difference is why there are two different casting codes differentiating them.
:D
Old Mar 21, 2006 | 03:29 PM
DYRcivic's Avatar
96-00 ex = s40 good tranny
92-95 ex = aluminum shift fork
96-00 ex = Steel shift fork
Old Mar 21, 2006 | 06:38 PM
schardbody's Avatar
sorry, thats right, i just knew they all say S20
Old Mar 21, 2006 | 06:41 PM
NMZ's Avatar
NMZ
up fo rreference later
Old Mar 21, 2006 | 06:44 PM
93civicsedan's Avatar
Default Re: (dontgivafuk)
anyone have pics of where its stamped B000 on the ex/si tranny? thanks.
Old Mar 21, 2006 | 11:02 PM
NazVil86's Avatar
Default Re: (93civicsedan)
i forgot where its located, isn't it where the clutch and pressure plate and flywheel go? or its on the outside- if its on the outside id be more than happy to put one up in the morning, but ours just got installed with stage3clutch but yah, lemme know.
Old Mar 21, 2006 | 11:10 PM
byronl's Avatar
the stamp is to the right of the fill plug
Old Mar 22, 2006 | 04:09 AM
schardbody's Avatar
yep, its in a nickel sized circle to the right i believe of the fill plug.
DeathByBoost
Aug 13, 2006 07:53 PM
99eciVic
Dec 9, 2004 12:44 AM
EK45VTi
Oct 27, 2004 12:47 PM
Kyles ej1
14
Aug 17, 2004 04:08 PM
onesick4dr
Nov 11, 2003 09:06 AM
