Fuel, no spark no start:(
Guest
Posts: n/a
The car just had a tune up and now it wont start. it ran for a couple of minutes the after that it shut off and now wont start. im geting fuel but no spark. checked all fuses and relays and the ignition coil. the tranny ground and valve cover ground and it still wont start. car ran fine till this day of the tune up what could have happened in that short period of time of changing cap rotor and wires. the spark plugs are like brand new. help me pleaase!!! and yes ive search!!!
(93 honda del sol, with b18b engine swap, and gsr trani)
which fuses did you check, also get a test light and see if you are getting power to the distributor, and then check your timing, also do some checks on things like your igniter
there is a ignition coil under the dash, i think it is number 9
dan89crxsi
Feb 10, 2007 02:44 PM
majinx4
Jun 2, 2006 06:42 PM
