Need your help for H22A
Old Mar 21, 2006 | 06:53 AM
JL_9110's Avatar
Default Need your help for H22A
I am looking for the racing items....
1. Racing Cam
2. Racing piston
3. Any suggestion to improve the engine performance.
Actually my H22A already installed the full set of cooling system like oil cooler, low temp radiator valve.......
Old Mar 21, 2006 | 09:16 AM
kulrevon's Avatar
Default Re: Need your help for H22A (JL_9110)
well I would say for info about the h22 go to the prelude forum. but I gaurantee the way you are talking you will get flamed and told to search.
I don't know what you mean by "racing". There is an official cam thread in the prelude section go look at it. as for pistons only mahale gold series pistons or stock are proven to work without sleeveing the block.
more performance - high compression valves. valve springs/retainers. port/polish. a "good" (an-r, kteller, greddy with 2.5 mod) header.
a way to tune (Hondata)
hope this helps.
and I am guessing a "radiator valve" is the thermostat.
Old Mar 21, 2006 | 09:24 AM
Hondaaccordvtec's Avatar
Default Re: Need your help for H22A (kulrevon)
first and foremost - welcome to HT!
You may want to search the archives here in the prelude forum and also definitely setup a budget for your car. Buying and adding parts can easily get way out of hand and become a $$ pit.
Definitely read the Prelude FAQ sticky at the top of the page.
Old Mar 26, 2006 | 04:39 AM
JL_9110's Avatar
Thnak you very much guy. Sorry about that my english is very poor. And I will searching prelude forum. However. Did any one know that the thermostat from SPOON? Which will open while water TEMP at 60*c. But I wonder is that the real one or not. Cause I check SPOON web. They didn't have tis product.
DaInFaMMuS1
16
Mar 9, 2009 05:09 AM
2lude4u
May 4, 2006 06:57 AM
w0rst1uck3v3r
Feb 21, 2006 12:07 AM
MLBZ521
Sep 10, 2005 08:51 PM
