ACL H22 bearing question
I just ordered a bearing kit and I'm not sure if I have the right ones. These are for my JDM 95 H22A. I'm pretty positive my rods bearings are the right ones, but very unsure about my thrust and main bearings.
The part numbers that I have are as follows:
Rod 4B1936-STD
Main 5M1957-STD
Thrust 1T1957-STD
On the ACL pdf file catalog the part numbers for main bearings on an H22A1 are both 5M1937 (50mm shaft size) and 5M1957 (55mm shaft size). Someone on here said that there are two different sized main bearings for H22's. 94-97 are 50mm journals and 98+ are 55mm journals. Is this true?
As for my thrust washers, on the package itself, someone wrote 'B18C' in a sharpy. On the ACL catalog it says that the part number for thrust washers on an H22A1 is 1T1937, but I also read here on HT that I have the correct thrust washers.
I am now assuming I have thrust washers and main bearings for a 98+ H22? I just need to verify before I send them back.
Rod 4B1936-STD
Main 5M1957-STD
Thrust 1T1957-STD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">yes, there are 50 and 55mm mains. Not sure if the GSR thrust washers are the same.....</TD></TR></TABLE>
Is that for the correct years though? 94-97 = 50mm and 98+ = 55mm?
Innovation
Jun 7, 2005 03:00 PM
