Accord Spring install Help!
Old Mar 20, 2006 | 10:28 PM
jokercykoe's Avatar
x3
Default Accord Spring install Help!
We're installing some skunk2 springs on my friends 94 accord. Got the springs on the shocks fine, and installed the fronts fine, but when we got to the rear, we ran into a problem. We can't get that one Pin into the hole behind the brakes.
That one pin that goes through the 2 holes on the bottom of the shocks. Can anyone give any advice on how to line up the bottom of the shocks so that the Pin goes through so we can finish this tonight?
sorry if i'm unclear on my question, but any help is welcome!
Old Mar 21, 2006 | 07:47 AM
SneezinCD5's Avatar
Default Re: Accord Spring install Help! (jokercykoe)
Yo will probably have to compress it again and line everything up. I ran into the same problem with my Gf's 96 V6. I also used Skunk2 springs and they rode like crap. Had to put the OEM springs back on after about 2 weeks. Couldn't take all the bouncing. OMNI POWER!!
Old Mar 21, 2006 | 09:25 AM
Hondaaccordvtec's Avatar
Default Re: Accord Spring install Help! (SneezinCD5)
you cna use a punch or awl to line up the pin hole.
Old Mar 21, 2006 | 12:09 PM
iam7head's Avatar
Default Re: Accord Spring install Help! (Hondaaccordvtec)
compress the spring and make sure everything seat right, most of the time the upper spring seat won't budget and all you can do twisting it is moving the bottum seat, which will affect the ride height.
this is way you should make a white line for alignment purposes before removing the old spring
Old Mar 21, 2006 | 05:25 PM
jokercykoe's Avatar
x3
Default Re: Accord Spring install Help! (iam7head)
Thanks for all the help guys, got it figured out
jimmy o.
Dec 16, 2009 10:30 PM
TrueUntilDeath.com
Dec 30, 2004 01:37 PM
roydogg
Jun 5, 2002 07:18 PM
Razor
Dec 18, 2001 07:06 AM
