which dizzy is obd1 has internal coil and will run a h22a4. i need to know b4 they tow!!
Old Mar 20, 2006 | 08:06 PM
djsire's Avatar
Default which dizzy is obd1 has internal coil and will run a h22a4. i need to know b4 they tow!!
its in the title. i need to know asap
and plese dont say jdm p13 caseu ill never find that in a junkyard
Old Mar 21, 2006 | 03:59 AM
v4lu3s's Avatar
RTFM
you need an obd1 internal coil distributor for an H series engine. you will not find it in a junkyard, unless that junkyard is in japan.
Old Mar 21, 2006 | 05:33 AM
djsire's Avatar
Default Re: (v4lu3s)
is there anyway i coudl use an accord dizzy or a dseries dizzy? i heard they have the same caps and rotor
also what ignitor, coil, cap and rotor is used on the jdm dizzy. so i dont have to go through this fiasco a second time
Old Mar 21, 2006 | 05:52 AM
djnikko's Avatar
Default Re: (djsire)
Borrow an MSD off a friend possibly? This will give you an external coil...
Old Mar 21, 2006 | 12:44 PM
djsire's Avatar
Default Re: (djnikko)
fixed it the black and yellow wiere was loose. the previous owner had it twisted together. i twisted it hard and now it works but breaks up at high rpm.
turbostd
May 1, 2007 10:03 AM
drSquish
Mar 13, 2006 06:11 AM
VNTEC
Jul 11, 2004 04:12 PM
