quick question?????//
Old Mar 20, 2006 | 07:55 PM
mikegeezy's Avatar
Default quick question?????//
is there a knock sensor on the d16y8? if so where is it located? thank you.
Old Mar 20, 2006 | 07:57 PM
turbochargeb18c's Avatar
BANNED
Default Re: quick question?????// (mikegeezy)
im not to familar w/ the d series # on the block but all the 92-95 sohc vtec doesn't have a knock but the obd-2 96 and up got one...someone correct me if im wrong..
Old Mar 20, 2006 | 08:01 PM
ccjustin's Avatar
Yes, it is slightly higher and toward the driver side of the oil pressure sensor. Both are located on the back of the block below the Intake Manifold, but abouve the oil filter. The knock sensor has a blue clip with a single red/blue wire, and is a BITCH to take off! You will probably break it, as I did, they are $117 from honda. You can use any other knock sensor from a B-series also
handa
Aug 29, 2010 04:47 PM
JDMislander
Mar 26, 2010 06:01 AM
Tzarinque
Apr 6, 2008 03:32 AM
slowerTHANmollasses
Nov 3, 2005 02:07 PM
Atheist
Apr 18, 2004 10:14 AM
