Emmisions
Old Mar 20, 2006 | 06:30 PM
Vtecattack's Avatar
Default Emmisions
I want to go with a ressonator over a catalitic converter. I was wondering if anyone Knows how to keep the resonator on and still pass emmisions. Keep in mind i live in maryland and the emmisions test is done through the computer so the only way you fail is if an engine check light goes off.
thanks
Old Mar 20, 2006 | 07:40 PM
BB6racer's Avatar
o2 sensor simulator? its the only thing i can think of that might work.
Old Mar 21, 2006 | 07:01 AM
Vtecattack's Avatar
can either one of you elaborate because i am not sure what you mean and how that helps me
Thanks
Old Mar 21, 2006 | 07:28 AM
syntax.'s Avatar
Default Re: Emmisions (Vtecattack)
not sure if its the same in maryland as it is in MA, but they only do the computer check on OBD2 cars, they still do the sniffer test on OBD1 cars.
If you have an obd2 then search for the 02 sim trick, like mentioned by BB6racer.
I will also take this time to recommend a high-flow cat over a resonator.
Old Mar 21, 2006 | 09:20 AM
Vtecattack's Avatar
thanks
scarney
Oct 25, 2008 11:43 PM
MaGoodc2
Feb 18, 2006 02:53 PM
MikeTV
May 13, 2003 12:14 PM
paulyman
Aug 26, 2002 04:40 PM
TurboSedan
Oct 15, 2001 06:04 PM
