AEM Fuel Rail Leaking
Alright so basically as the title says my fuel rail is leaking. I searched and could not find an answer to it besides but teflon tape on it...only problem with that is that if the fuel were to eat through the tape and it got into my injectors i would be fucked... so yeah should i just try to tighten it more or what? its coming out of the screw next to the FPR, the one you tighten with an alen wrench.
well ok heres the deal....it *was leaking. i just tightend it up and its not leaking gas any more but now occasionally it smells like gas when i have the heat on.
Well before i even think about using the teflon im going to find out where its leaking from. Throw some soapy water on it and then ill determine if i need to use the teflon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Check the o-ring first then tighten it down until it stops leaking.
</TD></TR></TABLE> i had this same problem last night when putting my manifold on i went and got a new oring and its mint. give it a shot
alright since it seems like a few people are sayin that I guess that may be my problem lol. im goin to check it out right now.
So yeah it wasn't the FPR o-ring im assuming now that its an injector o-ring. considering the fact that gas is basically spewing out of the middle right injector. so that means tonight after work i get to take off the rail and have fun with that in the cold. apparently patroleum jelly works wonders on that.
tooquik209
Sep 11, 2012 12:40 AM
RTW DC2R
Sep 3, 2002 04:39 PM
