VTEC timer
I installed a VTEC timer and was wondering when the best RPM range it is to set VTEC for when your racing its a B16a also when the best shift points are to get a fast time. Thanks for any help.
i hope you mean a VTEC controller. It is set from the factory at 5500 because honda engineers saw thats where it was best. You can try different rpms and see what you get. I'd say try 5000...whatever, make sure you get some VTEC oil while ur at meijeirs too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaniceday »</TD></TR><TR><TD CLASS="quote">stock crossover is the best for a stock motor .. vtec controllers are a waste IMO </TD></TR></TABLE>
Apex'i can tell you otherwise with the money they make from it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumped_ej1 »</TD></TR><TR><TD CLASS="quote">set to hit vtec at idle then that **** would be sick!</TD></TR></TABLE>
hell yeah! you'll win races before they even start! w00t!!!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00siandrew »</TD></TR><TR><TD CLASS="quote">What is this vtec oil you speak of?</TD></TR></TABLE> you have to pour 3/4ths of a cup of water into your vtec solenoid and it will produce the vtec oil by itself
Vtec controllers do nothing but send a 12v charge to your solenoid. Does nothing for your motor because your cams don't change neither will your fuel input. Just put it back on eGay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumped_ej1 »</TD></TR><TR><TD CLASS="quote"> you have to pour 3/4ths of a cup of water into your vtec solenoid and it will produce the vtec oil by itself </TD></TR></TABLE>
DON'T DO THIS
there is no such thing as vtec oil, its a term some smart ***'s use on here to act cool and to act like there smarter then everyone else.
you can only get vtec oil from a dealership (joking)
The same oil your vtec solinoid is the same oil you us when you do an oil change. It's just regular motor oil.
DON'T DO THIS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky »</TD></TR><TR><TD CLASS="quote">Vtec controllers do nothing but send a 12v charge to your solenoid. Does nothing for your motor because your cams don't change neither will your fuel input. Just put it back on eGay. </TD></TR></TABLE>
WRONG.. They never even get patched into the Vtec solenoid circuit.. I can tell you wired yours up hella good..
They alter Map signal to get a desired affect along with other things.. It's the most whored out hack known to honda ECU's.. it's trash.. Don't use one at all, especially on a boosted engine unless you like picking up parts.. it makes your car run rich and retarded or lean and advanced.. JUNK..
I do wanna get a V-TEC pressure guage so I can get my V-TEC to hit HARD! ;-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">
DON'T DO THIS
there is no such thing as vtec oil, its a term some smart ***'s use on here to act cool and to act like there smarter then everyone else.</TD></TR></TABLE>
what the hell are you talking about. I am not trying to be a smartass or act cool. I am just quoting that ricer song...Got some vtec sauce for my type R burger.
DON'T DO THIS
EK [30-85]
Nov 24, 2005 08:01 PM
