Suspension & Brakes Theory, alignment, spring rates....
Bedding Brake Pads and Seasoning Rotors?
Old Mar 20, 2006 | 05:38 PM
Understeer's Avatar
Default Bedding Brake Pads and Seasoning Rotors?
I know how to bed brake pads and season rotors, however here's unique situation that I have.
This saturday I put new Axxis Ultimate brake pads on with the normal rotors on my Integra. I bedded the pads in properly.
However, the next day I put new rotors on the vehicle.
Obviously the brake pads are bedded, but with the old rotors.
To season rotors you definetly need to drive them for about 6 days and don't brake too hard, then you proceed to the next step. On the flip side, these new pads are not bedded with the new rotors.
I don't want to bed these pads in, because it will cause excessive heat to the rotor and it won't settle in right.
What should I do?
I'm thinking to use the brakes nicely for a few days, and then do a full brake bed in process.
Old Mar 20, 2006 | 06:04 PM
MattD@Stoptech's Avatar
Default Re: Bedding Brake Pads and Seasoning Rotors? (Understeer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Understeer &raquo;</TD></TR><TR><TD CLASS="quote">
wha?
Here is what you should do:
http://www.stoptech.com/tech_i...shtml
Old Mar 20, 2006 | 07:05 PM
Understeer's Avatar
Default Re: Bedding Brake Pads and Seasoning Rotors? (El Pollo Diablo)
So rotors don't need to be seasoned?
According to this it does? It says not to bring the rotors up to extreme temperatures:
http://www.baer.com/Support/Te...pID=4
Old Mar 20, 2006 | 08:57 PM
All you're really doing is putting a pad transfer layer onto the surface of the rotor. The rotors really don't do any "settling in"
Old Mar 20, 2006 | 10:44 PM
Tornadom's Avatar
Good to know. I will be doing my brakes soon. Thanks.
Old Mar 20, 2006 | 10:55 PM
Tyson's Avatar
youre fine when putting new rotors on used pads.
i find an issue when you use the same rotors with different pads. rotors dont like that. part of the process is the pad material gets impregnated into the rotor. it doesnt like two different pad materials on the same rotor.
Old Mar 21, 2006 | 08:04 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Bedding Brake Pads and Seasoning Rotors? (Tyson)
It's easy to tell when new rotors have a good layer of pad material on the surface. They will look slightly gray on the rotor surface (instead of bright silver)...
You defiantly want to re-do the brake in procedure (as detailed on stoptech's website) when you install new rotors.
Old Mar 21, 2006 | 12:00 PM
Default Re: Bedding Brake Pads and Seasoning Rotors? (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">It's easy to tell when new rotors have a good layer of pad material on the surface. They will look slightly gray on the rotor surface (instead of bright silver)...
You defiantly want to re-do the brake in procedure (as detailed on stoptech's website) when you install new rotors. </TD></TR></TABLE>
Same for old rotors, even street pads like axxis ults will go into abrasive mode at a low enough ambient temp (40's or so it seems) which can often remove the pad deposition layer from the rotor requiring another bed-in.
Old Mar 21, 2006 | 06:37 PM
Understeer's Avatar
The rotors are brown/greyish color now, except for the inner rotor - it has a blue tinge. Should I be worried. I have done the procedure twice now.
Old Mar 21, 2006 | 06:39 PM
94eg!'s Avatar
#1 Super Guy
Loved
Your good to go...
Try to let them cool now for a couple hours with the parking brake off...
Old Mar 21, 2006 | 07:08 PM
Understeer's Avatar
Vehicle is parked inside and won't be driven until tomorrow morning. Rear pads/rotors were not replaced, so having the parking brake on doens't make a difference. But the parking brake is not on.
a.wax
Sep 15, 2007 06:53 PM
crx00
Apr 4, 2006 08:38 PM
weedtank
May 9, 2005 10:23 AM
ophdehEEzY
Mar 8, 2003 07:06 PM
Weston
Jun 20, 2002 09:56 AM
