Power locks broken
Do the others work? Did they fail at the same time? Could be the motor that actuator for the unlock lock died out on both your front doors. Does it sound like its trying to unlock or lock when you press the button?.
Hmmm might be a ground issue. I doubt all 4 went out. I think all of the door locks and windows ground out on the driver side but im not too sure. You pull off your door handle to see if the plugs on the door handle are connected where the unlock/lock mechanism is?
