Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
1999 Honda CRV flashing check engine light with 25PSI in cylinder #1
Old Mar 20, 2006 | 01:42 PM
zthonda's Avatar
Default 1999 Honda CRV flashing check engine light with 25PSI in cylinder #1
I have 1999 Honda CRV have flashing check engine light. Checked compression on cylinder #1 it only have 25PSI. the car have 120k. Any one can help me what option I have with engine? I went a place they told me they can rebuild top of the engine for $1000. Is this a good thing to do with the car. Thanks a lot for any help.
Old Mar 23, 2006 | 05:13 PM
Ross 2.0's Avatar
In a Junkyard near you.
Honda has a service bulliten for this. The exhaust valves in #1 have recessed into the head causing them not to close propperly.
You need to replace the head and valves.
If you wish to sell it let me know.
Old Mar 23, 2006 | 06:49 PM
zthonda's Avatar
Default Re: (MooGoCow3)
Thanks MooGoCow3. Where can I access this Bulletin? Does Honda provide fix on the problem?
Old Mar 25, 2006 | 04:37 PM
alpine_hikr's Avatar
Default Re: (zthonda)
yeah the fix is to replace the head and valves.
Old Mar 30, 2006 | 10:53 AM
gotboostedvr6's Avatar
not too cut throats but im in nj and in the markett to buy a vehical like what you have please contact me via private message or email me at gotboostedeg@gmail.com
cash in hand
Old Mar 31, 2006 | 06:59 AM
Stripped Honda's Avatar
99-0104
Default Re: (gotboostedvr6)
i have done a few of these at the shop and have found that you can usually just do a valve job and replace 1 or 2 valves and you will be fine ... i have never changed the head ...
miaozer
Feb 4, 2015 06:32 AM
alldrew
Nov 5, 2008 06:22 AM
hckyNhonda29
Jan 18, 2007 07:27 PM
