Mig welding gas/regulator question
Old Mar 20, 2006 | 01:32 PM
vegaskurt's Avatar
Default Mig welding gas/regulator question
I'm new to the solid wire gas welding, all I have done is flux core and stick welding. So here is my setup/problem.
I finally got a hobart 140 and it came with an argon regulator. I have a 5lb bottle of co2 and a similar size bottle of argon... What kind of regulator or hardware do I need to make this all work together to make a 25/75 mix?
Old Mar 20, 2006 | 01:39 PM
ManBearPig4silly's Avatar
It comes premixed.....
do people mix their own? Seems like it could work.....
Old Mar 20, 2006 | 01:56 PM
vegaskurt's Avatar
Default Re: (I4sillypwr)
I diddnt buy pre-mixed becuase I see myself doing some 100% argon at times and 100% co2 at others. Im thinking if I get a co2 regulator and some kind of Y splitter that might work. But I dont want to ghetto this.
Old Mar 21, 2006 | 06:34 AM
Yeah I'm not sure how it will work since I've never done it that way but you could buy a splitter and another regulator, split after the regulators into the one hose going into the welder and adjust the regulators to mix it at a 75/25 ratio...........seems ghetto and more expensive than buying a bottle of premixed tho.
Old Mar 21, 2006 | 08:03 AM
vegaskurt's Avatar
Yeah, that idea was silly. I took my un-used 20cf bottle of argon back and got a 55cf bottle of mix. I should be good now.
Old Mar 21, 2006 | 11:04 PM
supercreed2002's Avatar
Default Re: Mig welding gas/regulator question (vegaskurt)
55cf bottle? how big is that anyways? I was gonna start big...
Old Mar 21, 2006 | 11:31 PM
tonydatyga's Avatar
Default Re: Mig welding gas/regulator question (supercreed2002)
55cf is like a scuba tank. The "average" helium balloon tank is about 80cf for reference
Old Mar 22, 2006 | 05:29 AM
Importordomestic's Avatar
Default Re: Mig welding gas/regulator question (tonydatyga)
have you ever used an OXY/Acetelene torch? that setup is exactly the same as you have described. all you would have needed was another set of gages and requlators. then you mix it with 3parts Argon and 1 part C02. Yes it wuld probably take a minute or 2 to get it dialed in but it wouldnt be that hard.
Old Mar 22, 2006 | 07:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonydatyga &raquo;</TD></TR><TR><TD CLASS="quote">55cf is like a scuba tank. The "average" helium balloon tank is about 80cf for reference</TD></TR></TABLE>
ohh...I was wanting at least a 178cf tank.
b16bri
Welding / Fabrication
13
Nov 17, 2010 01:39 PM
ashb82
11
Feb 2, 2010 01:13 AM
mrbsponge
12
Mar 26, 2005 06:02 AM
sporkcrx
Aug 6, 2003 06:24 AM
