Engine Gurus! Give me your advice and opinions on my planned B18A build-up!
Old Apr 2, 2002 | 09:35 AM
tightDA8's Avatar
Default Engine Gurus! Give me your advice and opinions on my planned B18A build-up!
Engine Guru's i might be getting this setup very soon and very cheap and i was wondering if any of u guys have done this...Good and Bad points?
96 B18b Full Top End (everything)
3 angle valve job
port and polished head
JG 304 Cams w/ Skunk2 sprockets/ Or Crower equivalents
Ported TB/IM
Full straight pipe exhaust /Cold Air Intake
Engine Tuning
I know its gonna make sum decent low cost power, but i'm wondering if any of u guys have done this already. Help a brotha out!
Old Apr 2, 2002 | 11:57 AM
Jackson's Avatar
Default Re: Engine Gurus! Give me your advice and opinions on my planned B18A build-up! (tightDA6)
get some pistons. used b16 pistons if you are really on a budget.
Old Apr 2, 2002 | 12:21 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Engine Gurus! Give me your advice and opinions on my planned B18A build-up! (Jackson)
What kind of c/r will you get by using the B16a pistons or the type-r pistons an the B18a/b? What will have to be modified to use these pistons and will the setup be reliable? I am also thinking about using these pistons also.
Old Apr 2, 2002 | 12:27 PM
PoWeRBaN_PaNdA's Avatar
Default Re: Engine Gurus! Give me your advice and opinions on my planned B18A build-up! (FrostyDC4)
i have usdm itr pistons in my car very reliable had them for about 4000 miles no problem yet only thing you will need to do is shave the rods to fit the pistons and pump higher octane gas so you don't detenate
Old Apr 2, 2002 | 12:58 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Engine Gurus! Give me your advice and opinions on my planned B18A build-up! (notec_racer)
Really is that all you have to do? How hard is it to shave the rods? So besides the pistons and the new rings what else will I have to buy to make this work?
Old Apr 2, 2002 | 01:26 PM
Jackson's Avatar
pistons is all you need. but if you want to put some money into it, go oversized, get new bearings, new gaskets. any machine shop can shave the side of the rod for you to put the itr piston on there. you will need the piston, wrist pin and new rings. compression with us itr pistons will be 10.32:1. with 1st gen or usdm b16a pistons, your compression will be about 10.8:1. with 2nd gen jdm b16a pistons, compression will be almost 11:1. 10.98 to be exact. hth.
Old Apr 2, 2002 | 01:38 PM
qwkteg125's Avatar
yup the pistons are a bolt-on affair. bring the rods & pistons to a machine shop, where they will press out your old pistons, shave your stock rods 1mm on each side, & then install the new pistons for you.
if your block is getting tired, you can also bore & hone it. then you will need .025 overbore pistons. as for new compression ratio, check this guide:
http://www.c-speedracing.com/howto/c.../compcalc.html
Old Apr 2, 2002 | 02:06 PM
you will need all the stuff jackson suggested
Old Apr 2, 2002 | 05:24 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Cool thanks . You answered all of my questions. The pistons are relatively inexpensive compared to the jrsc I had planned. Thanks again!
Old Apr 2, 2002 | 05:32 PM
frostwhite_92's Avatar
*If* I were to build a B18 non-VTEC, here's what I would do:
B20, re-use the B18 top end (are you paying extra for the '96 top?) since you are having the head ported & are going w/ aftermarket cams
Headwork: Portflow
Endyn pistons
Crower 403/Crower valvetrain
Send the throttle body to RCE to have it bored out (yes, they still offer this service) - while you're at it, send them your injectors to be balanced/blueprinted
3" Slatertake (use a D-51 battery to get it to fit)
Apex'i SAFC, adjustable FPR (I like the Vortech units), dyno-time
Frosty
Old Apr 2, 2002 | 11:21 PM
tightDA8's Avatar
Default Re: Engine Gurus! Give me your advice and opinions on my planned B18A build-up! (frostwhite_92)
thanks for all the replies fellas..
Frostwhite92, i am gonna use by B18 block to keep costs down...I'm only payin 120 bucks for the complete 96 top end. The headwork will be done very cheap through a friend. I was checkin out some of crower's offerings today and i'm deciding if i will go with their products or JG's. if i go JG it will be hooked up very cheap, but i want to try to find someone who has experience with crower products first...All i really want is make my car just a bit faster but not spend too much cash, since i'm savin up for another car..If i can lay down at least 150 to the wheels, i will be happy with that!
Keep the opinions rollin...
Old Apr 3, 2002 | 08:02 AM
blacksheep's Avatar
3 angle valve job
Ported TB/IM
Engine Tuning
I hope you put some kind of muffler on that exhaust. Full straight pipe sounds so rice! Kinda hard to have a clean looking old-school teg, when it sounds like a weed-eater on steroids. And I agree that pistons will help a lot in your quest for 150whp. You may also want to do some ecu tuning, and add a S-AFC in there also. With all this extra airflow going on, you will definitely need to have a way to tune your fuelmap.
I'd like to see a pic of your car. I love G2 Integras! My 93 is about to hit the streets, and I can't wait.
Old Apr 3, 2002 | 09:41 AM
tightDA8's Avatar
Default Re: Engine Gurus! Give me your advice and opinions on my planned B18A build-up! (blacksheep)
Oh yes, it will have a muffler on it! hehe...I meant no cat. I'm gonna run an old school HKS muffler (the one with the two small dual tips) on it. As far as the fuel map tuning, i'm probably gonne go either the AFC route or Hondata...Oh yeah, i'll post a pic of it on friday...Imagestation is down today...
[Modified by tightDA6, 10:42 AM 4/3/2002]
Old Apr 3, 2002 | 09:55 AM
GM2000ITR's Avatar
New User
I've got CTR pistons on LS rods (roughly 14k mi.) just sitting in my garage! You'll obviously just need to get new bearings, but mo machining is necessary. I need $$ bad right now! Mke me an offer if you're interested!
Old Apr 3, 2002 | 10:59 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Engine Gurus! Give me your advice and opinions on my planned B18A build-up! (GM2000ITR)
Aren't the JG cams regrinds?
Old Apr 3, 2002 | 12:16 PM
D.Lansing's Avatar
Yes, don't get them
Old Apr 3, 2002 | 01:56 PM
ihaterice's Avatar
Default Re: Engine Gurus! Give me your advice and opinions on my planned B18A build-up! (D.Lansing)
get some crower 404s, crower valve springs, and retainers along with some itr or b16 pistons and you will be set...my car with itr pistons, shotpeened ls rods, cone air filter and custom exhaust put down 132 hp and 130 at the wheels, i figure i am gong ot get a dc 4-2-1 header, and the crower top end valve train and valves and i should be close to 155 whp or so
james
Old Apr 3, 2002 | 01:58 PM
robbin's Avatar
If you're raising compression and doing head work, I'd suggest crower 404 cams, with the springs and retainers. I've heard of a few people that use them on the street and have had no problems, and it'll give you maybe 5 more hp over the 403's for the same price.
-Chris
PS tell us how it goes, I still haven't decided what I'm going to do under the hood.
070-racing
Oct 26, 2014 04:55 AM
civic-r11
Jan 29, 2007 01:46 PM
Doctor VTEC
Jul 14, 2006 09:18 PM
Sleepin
Jul 16, 2003 06:41 PM
comptechgsr
Dec 26, 2001 09:34 PM
