Price CHECK Tell me if im gettin ripped off or not!!!
Old Mar 20, 2006 | 12:06 PM
fakeownzjoo's Avatar
Default Price CHECK Tell me if im gettin ripped off or not!!!
Getting a used but new entire Throttle body installed and idle adjusted for $300... just want to know if das a good price...
Old Mar 20, 2006 | 12:12 PM
E46Kid's Avatar
more info stock? aftermarket?
Relic1's Avatar
a 92 CX TB? ITR TB? aftermarket TB?
is this parts and labor? port matching required?
you need to give a load more info.
Old Mar 20, 2006 | 12:14 PM
turboxsi's Avatar
Default Re: Price CHECK Tell me if im gettin ripped off or not!!! (fakeownzjoo)
do it yourself its easy and saves you $300. Do a search and you will see its not hard https://honda-tech.com/zerosearch I just put on my ITR t/b with no problems just reset the ecu and you idle will be fine (unless you have a extremely large t/b bore or other internal mods).
What do you have anyways, as that will also make a difference???
Old Mar 20, 2006 | 12:21 PM
sorry not enuff info there lol.....stock 96' CX T/B and yes it is parts and labor. Everything is stock on that car btw.
Old Mar 20, 2006 | 01:14 PM
Relic1's Avatar
well considering I think you can buy that TB used but in good condition for $50 (at most) and install it in a hour with simple hand tools....
Old Mar 20, 2006 | 01:17 PM
O RLY's Avatar
Default Re: (Relic1)
$300 gets you a new Skunk2 TB + install it yourself. It is so easy to do...just make sure you get the TB gasket with the SK2 if you buy it.
Old Mar 20, 2006 | 03:57 PM
well..... i found out the TB aint bad it was just dirty and it was leaking so... im gonna get a rebuilt kit and just do that... thanks guys..
Old Mar 20, 2006 | 04:22 PM
B20Vtech_EK9's Avatar
if its a type-r throttle body its worth it
Fliptard
27
Jan 25, 2014 04:03 AM
Romo Pyro
Apr 20, 2010 07:50 AM
jizzer671
Jul 13, 2007 07:55 AM
Wiseguy619
Mar 3, 2004 05:26 PM
vtec-izm
Nov 18, 2003 08:38 PM
