600rr hp?
Old Mar 20, 2006 | 11:10 AM
hondatuner20's Avatar
Default 600rr hp?
Just wondering how much hp does a stock 2006 600rr have?
Old Mar 20, 2006 | 11:18 AM
MSchu's Avatar
My Name is Nobody
Default Re: 600rr hp? (hondatuner20)
plenty
Old Mar 20, 2006 | 11:21 AM
backlash's Avatar
'05 and '06 are the same. Here is an '05
Old Mar 20, 2006 | 11:25 AM
RynoDyno312's Avatar
Default Re: 600rr hp? (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">plenty </TD></TR></TABLE>
After some quick math, I've found that it would be roughly the same as a 2500lb civic with 750hp
Old Mar 20, 2006 | 11:32 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: 600rr hp? (RynoDyno312)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RynoDyno312 &raquo;</TD></TR><TR><TD CLASS="quote">
After some quick math, I've found that it would be roughly the same as a 2500lb civic with 750hp </TD></TR></TABLE>
Yea, that feels about rite.
Old Mar 20, 2006 | 11:37 AM
MSchu's Avatar
My Name is Nobody
nice
Carry on gentleman
Old Mar 20, 2006 | 11:53 AM
yimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RynoDyno312 &raquo;</TD></TR><TR><TD CLASS="quote">After some quick math, I've found that it would be roughly the same as a 2500lb civic with 750hp </TD></TR></TABLE>
Although that power to weight ratio may be correct, a 750 hp civic would walk a 600 from a roll/
Old Mar 20, 2006 | 12:01 PM
Default Re: 600rr hp? (yimmy)
what about the blackhawk whats that put down hp wise?
Old Mar 20, 2006 | 12:08 PM
yimmy's Avatar
Most bikes are listed here.
http://sportrider.com/bikes/14...ents/
Old Mar 20, 2006 | 12:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yimmy &raquo;</TD></TR><TR><TD CLASS="quote">
Although that power to weight ratio may be correct, a 750 hp civic would walk a 600 from a roll/</TD></TR></TABLE>
True, but that wasn't my point. I was just trying to illustrate how amazingly fast modern sportbikes are.
Old Mar 20, 2006 | 12:15 PM
yimmy's Avatar
Well said
Old Mar 20, 2006 | 12:21 PM
Nims's Avatar
Did you factor in the weight of the rider to the power/weight equation?
If you assume approximately 110whp and 400lbs for the bike, you get power/weight of 0.275 And for a 2200lb hatch that means you'd need 605whp. And 2200 with driver is pretty light. If you assume 2500lbs with a driver and gas which is more reasonable, it's only equivalent to 687.5whp.
If you factor in the rider, you're at more like 550-600lbs. At 600lbs and 110whp, that's power/weight of .183 For a 2500lb hatch that's equivalent to 458.3whp.
So while 600's are absurdly fast, they aren't quite as absurd power weight as you were saying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yimmy &raquo;</TD></TR><TR><TD CLASS="quote">Although that power to weight ratio may be correct, a 750 hp civic would walk a 600 from a roll/</TD></TR></TABLE>
This is definitely true. I'd bet that a 500whp civic would walk a 600.
That said, when I had a ~300whp civic I pulled on two losers on late 90's 600s. Which if you think about it isn't that hard. If you start a pull in their powerband in first, the bikes can't be full throttle because the front wheel won't stay down. If you start in the power band in 2nd, well, you're going too fast for the street.
All that said, bikes &gt; all.
Old Mar 20, 2006 | 12:34 PM
Duster's Avatar
Default Re: 600rr hp? (Nims)
not to mention that a civic with 600+ whp would not be able to get any traction whatsoever under WOT in first gear....youd need some fat slicks to keep that kind of power grounded in a FWD.
Way to get technical Nims
Old Mar 20, 2006 | 12:37 PM
Mag00n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nims &raquo;</TD></TR><TR><TD CLASS="quote">
That said, when I had a ~300whp civic I pulled on two losers on late 90's 600s. </TD></TR></TABLE>
What exactly made them losers?
Old Mar 20, 2006 | 12:54 PM
Odiedogcx's Avatar
AIRBORNE
Default Re: 600rr hp? (Macan00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Macan00n &raquo;</TD></TR><TR><TD CLASS="quote">
What exactly made them losers?</TD></TR></TABLE>
cause they lost, silly!
Old Mar 20, 2006 | 02:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nims &raquo;</TD></TR><TR><TD CLASS="quote">Did you factor in the weight of the rider to the power/weight equation?
All that said, bikes &gt; all. </TD></TR></TABLE>
I used a dry weight of 361lbs and the advertised horsepower of 108. It wasn't perfect, but I think it made my point.
Old Mar 21, 2006 | 07:42 AM
Nims's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Macan00n &raquo;</TD></TR><TR><TD CLASS="quote">What exactly made them losers?</TD></TR></TABLE>
The fact that I was in a "stock" civic and they were harassing me. I had a stock integra wheel, coilovers at barely lower than stock, black coated FMIC, and rusty straight 2.5" exhaust with a 42" resonator with a full muffler as well. As far as they knew the car was stock, yet they came up on both sides of me and were on and off the throttle staring at me.
Oh well.
I'm a biker, I wasn't hating
Old Mar 21, 2006 | 08:19 AM
Mag00n's Avatar
you are just as much a loser as they are
Old Mar 21, 2006 | 11:09 AM
Luke's Avatar
Depends what colour CBR
Old Mar 21, 2006 | 11:12 AM
Nims's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Macan00n &raquo;</TD></TR><TR><TD CLASS="quote">you are just as much a loser as they are</TD></TR></TABLE>
I bet you've never exceeded the speed limit on a public road. Thanks for criticism, this isn't kills and I'm not a child.
Old Mar 21, 2006 | 11:23 AM
Mag00n's Avatar
i dont race bikes when im in my 11sec crx and i dont race cars when im on my bike. way too many dumb ***** on the road in cars AND on bikes
my point was simply you are no better than them as you participated in the race
Old Mar 21, 2006 | 11:55 AM
Nims's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Macan00n &raquo;</TD></TR><TR><TD CLASS="quote">i dont race bikes when im in my 11sec crx and i dont race cars when im on my bike. way too many dumb ***** on the road in cars AND on bikes
my point was simply you are no better than them as you participated in the race </TD></TR></TABLE>
Oh snap! An 11sec crx, that has nothing to do with the conversation but thanks for the that. I don't care what your point is, you're wrong. I'm not even going to bother getting into that debate.
Even if you did have a valid point, it was completely unnecessary given the original thread and the demeanor with which I posted. I wasn't bragging, I was giving a reference point for the original poster. If you don't like my word choice, move on.
Old Mar 21, 2006 | 12:38 PM
Mag00n's Avatar
you are bragging about pulling on bikes with your joke of a civic. thats why i brought up my car.
And my point is correct. You call them a loser for racing YOU but your not a loser for racing them. Pot meet kettle
Old Mar 21, 2006 | 03:33 PM
Nims's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Macan00n &raquo;</TD></TR><TR><TD CLASS="quote">you are bragging about pulling on bikes with your joke of a civic. thats why i brought up my car.
And my point is correct. You call them a loser for racing YOU but your not a loser for racing them. Pot meet kettle</TD></TR></TABLE>
Did you just insult my civic and brag about your crx (which is a civic)? What was that about pot meeting kettle? FWIW, I don't have the civic anymore, but I'm sure my S2k and R6 are jokes too. CRX ftw!
As always, you made an assumption about my intent, flamed away, and you were wrong in the first place. I wasn't calling them losers for racing, I was calling them losers for antagonizing me, no doubt because they thought it'd be funny to humiliate me in a stock-ish civic. Also, for riding while in t-shirts and shorts. Understand yet?
Old Mar 21, 2006 | 04:31 PM
Apocalypse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nims &raquo;</TD></TR><TR><TD CLASS="quote">Also, for riding while in t-shirts and shorts. Understand yet?</TD></TR></TABLE>
I think it still fits.
Let's not get carried away... a 750hp Civic won't walk on **** 'cause it'll be broke as **** by 3rd gear.
