New guy needs help with project: B16, B18, etc
Old Mar 20, 2006 | 09:11 AM
EngineeredCivic's Avatar
Default New guy needs help with project: B16, B18, etc
Hey guys (and gals)
I'm new here and new to building up Hondas. I'm used to working on jeeps, toyotas, and other rockcrawling rigs. I'm familier with engine building, tranny building, custom fab, interior work. I also have some racing expereince from when I used to Autocross a 95 Mustang GT. I've helped friends work on their civics, eclipses, scion Tcs, etc and now I'm working on one myself.
One of my friends is stationed in Japan for 4 years and before he left he bought a civic from one of our friends or $2K. It's a 1996, plain silver HB completely stock. My buddy wants me to build this thing up for racing, mainly road racing; but he also wants it to fly down the 1/4 mile. So he has given me a decent budget and wants me to build this thing up. I've read the FAQ section on engine swaps and I know I want to rebuild whatever I buy so it can handle some boost. My question is which motor has the best selection of parts (pistons, better rods, etc) for this application. I want the engine and tranny to be as "bolt-in" as possible. From what I've read the B16 and B18C1 are good choices although they seem to have high compression. There seems to be an endless amount of choices since I'm going to rebuild whatever motor I buy to lower the compression to handle boost. I want to put a turbo kit on this car and push 300+ HP. Give me some advise so I can get started on this project, what would be a good platform to start with.
Oh, and be nice to the newB
Modified by EngineeredCivic at 12:41 PM 3/20/2006
Old Mar 20, 2006 | 09:16 AM
Default Re: New guy needs help with project: B16, B18, etc (EngineeredCivic)
Here's a picture I found on eBay of a car just like the one I'm building up. My "blank canvas"
Old Mar 20, 2006 | 09:20 AM
Sleepy_Red_hatch's Avatar
the b18c1 adores boost, eagle connecting rods and ARP rod bolts work well. upgrade the valvetrain at boost at 15 PSI and 300 should be close.
Old Mar 20, 2006 | 09:25 AM
x_outlaw_x's Avatar
go with lsvtec, those have low compression...get a b16 complete swap and pick up an ls block (b18a/b) and then put the b16 head on the ls block and it will be g reat for turbo
Old Mar 20, 2006 | 09:27 AM
-Gary-'s Avatar
Where in New Orleans are you from? I'm from Harvey...well...that was until after the storm. Since then I moved o Texas.
Old Mar 20, 2006 | 09:37 AM
Default Re: (scuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x &raquo;</TD></TR><TR><TD CLASS="quote">go with lsvtec, those have low compression...get a b16 complete swap and pick up an ls block (b18a/b) and then put the b16 head on the ls block and it will be g reat for turbo</TD></TR></TABLE>
the rod stroke sucks and i wouldent trust the lower capacity oil pump from the LS to supply the PR3 head with enough oil. JDM GSR with a sleeve = t3h w1n
Old Mar 20, 2006 | 10:27 AM
Default Re: (x_outlaw_x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">the b18c1 adores boost, eagle connecting rods and ARP rod bolts work well. upgrade the valvetrain at boost at 15 PSI and 300 should be close.</TD></TR></TABLE>
The B18c1 is what I've been leaning towards, is the tranny a good match for a turbo and is it also an easy swap into this EK? I've read about people mixing and matching B16 trannys on B18 engines, etc and still not clear on what the better setups are.
Is the B18C1 swap any harder than a B16 swap?
I've read a lot about the ls/vtec as far as a them being good/powerful engines. What is that advantage of having a non v-tec 1.8 liter bottom end over a B18c1 which has the better Vtec bottom end?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scuzz &raquo;</TD></TR><TR><TD CLASS="quote">Where in New Orleans are you from? I'm from Harvey...well...that was until after the storm. Since then I moved o Texas.</TD></TR></TABLE>
I'm over on the Westbank too. Just moved here in January. My wife is from Metairie
Modified by EngineeredCivic at 2:08 PM 3/20/2006
Old Mar 20, 2006 | 12:41 PM
x_outlaw_x's Avatar
lsvtec makes more power then a b18c1 and more torque
b16 tranny has shorter gears then the ls tranny which makes it better for drag racing
Old Mar 21, 2006 | 06:25 AM
TTT
Old Mar 21, 2006 | 07:56 AM
JeffBro's Avatar
Default Re: (EngineeredCivic)
Your asked about b series trannies...
Well as far as gearing goes heres the break down
heres how it does from most aggressive to least
b18c5/b18c r &gt; b16 &gt; b18c1/b18c gsr &gt; b18 ls &gt; b20
Though the b16 tranny has slightly better gearing than a gsr trans I dont think it would be significant enough to matter if your going to boost it anyways. Also hers a web site for b series trans if you want to see some numbers...
http://www.allmotorhonda.com/t...s.htm
Old Mar 21, 2006 | 08:01 AM
Default Re: (JeffBro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffBro &raquo;</TD></TR><TR><TD CLASS="quote">
k20 &gt; b18c5/b18c r &gt; b18c1/b18c gsr &gt; b16 &gt; b20 &gt; b18 ls
fixed it for you.
Old Mar 21, 2006 | 11:52 AM
The more I look at it the better a K20 swap is looking. More power and torque N/A plus the 6 speed tranny. It would be more money for the motor but I could put off the turbo, the K20s 200 hp would keep him happy for a while and later he can add the turbo to take it to 300 hp
What do you guys think?
Old Mar 21, 2006 | 01:20 PM
x_outlaw_x's Avatar
sounds like the best one, but do you know what is involved with that swap?
Old Mar 22, 2006 | 06:59 AM
-Gary-'s Avatar
If I had the money it'd be a k20 all the way. Kick *** NEW (ish) motor, 6 speed tranny and a LSD. Here's something else that pushes the k20 in your favor, Hybrid Racing is right accross the lake in Mandeville from you and they pretty much fabricate everything you need. Here's thier site: http://www.hybrid-racing.com/main.html
Old Mar 22, 2006 | 07:27 AM
Default Re: (scuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scuzz &raquo;</TD></TR><TR><TD CLASS="quote">If I had the money it'd be a k20 all the way. Kick *** NEW (ish) motor, 6 speed tranny and a LSD. Here's something else that pushes the k20 in your favor, Hybrid Racing is right accross the lake in Mandeville from you and they pretty much fabricate everything you need. Here's thier site: http://www.hybrid-racing.com/main.html</TD></TR></TABLE>
I've been reading this buildup on JDM civic
http://www.jdmcivic.com/forums...+swap
This guy is in N.O. too. Awesome build. Doing more research to see what all is involved
Old Mar 22, 2006 | 12:26 PM
TTT for the afternoon/evening crew
Old Mar 28, 2006 | 10:22 AM
-Gary-'s Avatar
When they make thier kits to where I can have A/C *and* power steering without busting the bank, I'll start looking for K-Swap parts. It just get's too damn hot from March to November in the South.
Old Mar 28, 2006 | 05:33 PM
EK9Greg's Avatar
OK that is a good starting car, well it all depends on what kind of racing you want to do, autocross is what I like more I would saying if I was you I would get a b20 block with a nicely ported b16 head making a b20/vtec motor and run some TWM TIB's will make good power and torque and will rev fast to keep you moving through turns, best bet is to use a really good header and exhaust, it will be a fast car and fun to drive every day and nice to play with some GT's hahahahah well nice for you not for them well good luck and hope everything works out just remember it all depends on what kind of racing you are going to be donin with the car just have fun doing it
Old Mar 28, 2006 | 05:50 PM
bsixteen's Avatar
how's it going fellow westbanker. if there is funds available i'd defintely go w/ the k20 and hybrid racing. come check out sportsnimports.com, one of the guys from hybrid w/ the k20 in his hatch posts on there sometimes i think. there was a video of him beating an evo hehe
Old Mar 28, 2006 | 05:58 PM
EK9Greg's Avatar
Default Re: (bsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen &raquo;</TD></TR><TR><TD CLASS="quote">how's it going fellow westbanker. if there is funds available i'd defintely go w/ the k20 and hybrid racing. come check out sportsnimports.com, one of the guys from hybrid w/ the k20 in his hatch posts on there sometimes i think. there was a video of him beating an evo hehe</TD></TR></TABLE>
thats true the k20 swap is a great swap but its alot of money but it is worth it you can see the videos on the hybridracing.com check it out, the k20 is a good motor and even better if you have to money to do it
MrXclusivE
Oct 31, 2008 10:59 PM
magicmancys
Sep 5, 2005 01:03 PM
