Suspension & Brakes Theory, alignment, spring rates....
A little handling help please
Old Mar 20, 2006 | 08:39 AM
mini-e's Avatar
Default A little handling help please
Since you guys know more about what I am asking that any board I have found-
I on the right track for a fun handling car and comfortable daily driver?
I have a 96 civic cx hatch with no power steering/ac- specs say 2250 lbs without me in it. I am setting it up for aggressive twisty driving- 7/10 on sections where i can see type stuff- nothing silly or sustained- no races or auto x, just a solid daily driver that i want to handle predictably and fairly neutral. So far all i have done is put 14" hx wheels with falken 512 175 65. (crappy tire, 1 ply sidewall, a mistake- they need 40lbs not to not fold up) and i installed front 24mm and rear 19mm sways. I handles pretty darned well considering imo, neutral on a feathered throttle, pushes a little power on, but it can be rotated with the brakes or with a quick turn-in adjustment while in a corner- in fact the negative trait that is showing is the rear wants to come out too easily. So springs and struts are in order- I bought koni yellows- and I am trying to select springs and already bought some eibach sportlines with a 310/275 spring rate and 1.75 or so drop.. am I on the right track for a fun handling car and comfortable daily driver? or would eibach pro kit 290/190 (or something with similar spring rate) be a better choice. My inclination would be to put the koni spring perch on the lowest setting at the back to get the rear down in either case, and I like the sportlines much tougher rear spring rate as I think it will keep the rear from swinging out (it actually feels like over sometimes) but wonder if expansion joints on interstates will be a nightmare (this is a road trip car too). the car will never be tuned past 140 wheel h.p. and is not going to get a closed diff.
any help appreciated.
thanks-
Old Mar 20, 2006 | 08:50 AM
.RJ's Avatar
.RJ
Default Re: A little handling help please (mini-e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-e &raquo;</TD></TR><TR><TD CLASS="quote"> 7/10 on sections where i can see type stuff- nothing silly or sustained- no races or auto x</TD></TR></TABLE>
Spend the money/time on autox - making yourself a better driver will pay much bigger gains than any $$ you can put in the car and its something you can always use.
Old Mar 20, 2006 | 09:10 AM
mini-e's Avatar
Default Re: A little handling help please (.RJ)
that is a thought- i am moving to portland in a couple weeks and will be living a mile or two from the track. I am cedrtain I would learn a great deal auto-xing. i already bought the shocks and springs and am looking for a little guidance as to tuning the suspension because i am in fact tuning the suspension.
thanks-
Old Mar 20, 2006 | 09:28 AM
94eg!'s Avatar
#1 Super Guy
Loved
Koni does NOT recomend using lowering springs on the "lowered" settings of their shocks. The lowerd grooves are really ment for stock springs or coil-over sleeves. The problem you would face is that most lowering springs are relativly soft & that would leave you very vulnerable to consistant bottoming out...
I have heard very good things about koni's with any eibach lowering, as well as neuspeed, lowering spring kit. Both offer very good quality & reasonable price. Your best to go with those springs to start out. And if you wish to go a different way later on, those springs will have a good resale value (very important if you don't know exactly what you want right now)...
You will be very pleased with the Koni's since they offer you a great range of adjustability. Dialing in the attitude of your car is very easy & also pretty fun...
Old Mar 20, 2006 | 09:42 AM
mini-e's Avatar
Default Re: A little handling help please (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Koni does NOT recomend using lowering springs on the "lowered" settings of their shocks. The lowerd grooves are really ment for stock springs or coil-over sleeves. The problem you would face is that most lowering springs are relativly soft & that would leave you very vulnerable to consistant bottoming out...
thanks- good to know, i'll go dow load pdf's from koni and eibach (if they have any) as i bought the shocks used (uninstalled) without instructions. i feel good about the koni's and am a little nervious about the springs being too hard as a daily driver.
Old Mar 20, 2006 | 09:47 AM
94eg!'s Avatar
#1 Super Guy
Loved
lowering springs are relativly soft. It's usually the "coil-over sleeve" springs you have to look out for. You won't be dissapointed...
Old Mar 20, 2006 | 10:04 AM
mini-e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">lowering springs are relativly soft. It's usually the "coil-over sleeve" springs you have to look out for. You won't be dissapointed...</TD></TR></TABLE>
thanks for the info!
Old Mar 20, 2006 | 03:18 PM
mini-e's Avatar
after reading about the ek sway bar related rip out problem i am going to go ahead with the sportlines as the jump from oem rear spring rate will help protect the frame from the sway induced loads. i should probably invest in one of the brackets that reinforce that area as well..
thanks-
Old Mar 20, 2006 | 08:33 PM
94eg!'s Avatar
#1 Super Guy
Loved
That is a good idea when using a 19mm rear bar. The EK subframe is very delicate...
Old Mar 20, 2006 | 10:52 PM
Tornadom's Avatar
You sound as if you are headed in the right direction. on the Konis. The Eibach Sportlines are a good starter spring, and later if you are ready to get some coil-overs your Konis will be ready too.
Old Mar 21, 2006 | 10:06 AM
mini-e's Avatar
Default Re: A little handling help please (Tornadom)
Thanks Guys- I look forward to getting this set up on the car.
nickart42
Suspension & Brakes
Dec 24, 2012 07:50 AM
jolt-tsp
Texas -OK -LA (Sales)
14
Dec 3, 2008 03:47 PM
nfinitecc
Suspension & Brakes
Dec 23, 2005 12:44 PM
turbochargeb18c
Suspension & Brakes
Oct 12, 2005 11:38 AM
Jason C SBB
May 4, 2003 07:01 AM
