H22A valve springs - egg shape, lemon shape
Old Mar 20, 2006 | 08:37 AM
PreludeZ's Avatar
Default H22A valve springs - egg shape, lemon shape
in manual is written that there are 2 different shapes of outer valve spring (egg shape and lemon shape) but it is not specified which is intake and which is exhaust spring...
Anybody knows?
Old Mar 21, 2006 | 02:45 AM
PreludeZ's Avatar
Default Re: H22A valve springs - egg shape, lemon shape (PreludeZ)
nobody knows which one is for intake/exhaust?
Old Mar 21, 2006 | 07:05 AM
pentaq's Avatar
Are they marked anyhow? As far as I know yellows go to the intake and blues to the exhaust side.
Old Mar 21, 2006 | 10:32 AM
PreludeZ's Avatar
Default Re: H22A valve springs - egg shape, lemon shape (pentaq)
no colours just this
Old Mar 21, 2006 | 11:00 AM
pentaq's Avatar
It says that the WIRE of the spring has some different shapes (someone corrects me if I'm wrong in this place).
From the begining: what's your problem? Do you have your valve springs mixed up and you don't know which is which?
Old Mar 21, 2006 | 02:23 PM
flyrod's Avatar
I think the free length is slightly different between the EX and IN valve springs. Measure them and compare against the spec in the manual.
Old Mar 21, 2006 | 03:38 PM
BlueLude94's Avatar
Default Re: H22A valve springs - egg shape, lemon shape (flyrod)
THIS IS JUST A QUESS!!!
But if I HAD to QUESS, I would say the lemon shape would be the intake side due to the reduced(limited) space from the VTEC lobe, but IDK????????
Old Mar 22, 2006 | 12:08 AM
PreludeZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">It says that the WIRE of the spring has some different shapes (someone corrects me if I'm wrong in this place). </TD></TR></TABLE>
You are right, the wires that springs are made of are different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">From the begining: what's your problem? Do you have your valve springs mixed up and you don't know which is which?</TD></TR></TABLE>
Exactly, the springs on valves are mixed...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">I think the free length is slightly different between the EX and IN valve springs. Measure them and compare against the spec in the manual.</TD></TR></TABLE>
YES THATS IT!!!
so, in the light of new evidence, it is now clear that the springs with LEMON shaped wire are for INTAKE valves (they are shorter = 45,16mm (1.778in)) and on the other side the springs with EGG shaped wire are for EXHAUST valves (they are longer = 46,72mm (1.839in))
Thanks to all who wrote to this thread!
Thanks for all your posts guys!
Campino
May 19, 2017 02:24 PM
jrnsr
Oct 12, 2011 10:02 PM
Hondaruss
Dec 18, 2010 09:17 PM
ZC DOHC CRX
Jan 23, 2009 04:27 PM
jdmb18c
Apr 4, 2005 03:30 PM
