Brake booster/MC opinions
Old Mar 20, 2006 | 08:24 AM
cheehee's Avatar
Default Brake booster/MC opinions
I'm going to install front and rear GSR disc brakes on my 00 hatch (Metal Master pads, Goodridge steel braided lines) and am not sure which BB/MC to run. I currently have a 1" MC and BB combo from a DC (how can I tell for sure?) but have heard that the pedal will be rock hard. Can anyone comment on this setup for mostly street use? Should I run the 15/16" MC instead?
Old Mar 20, 2006 | 09:03 AM
pdiggitydogg's Avatar
This is the setup I run - 1" mc/bb, integra calipers
I like it much better than the civic components.
It will not be rock hard with integra calipers, only with smaller ones from a civic.
It will feel slightly firmer than stock. It is more recognizable with small calipers because you are moving a lot more fluid to compress small pistons - with the larger ones, it is not as noticable (slightly more with stainless lines)
The side of the master cylinder should have a 1 on it.
You will not notice the difference between a 1" and a 15/16 mc
Old Mar 20, 2006 | 09:14 AM
cheehee's Avatar
Default Re: (pdiggitydogg)
thanks for the reply. Yeah, the MC does have a 1 on it. I noticed that the hard line connections are not in the same spots as my stock MC. Did you have to bend and reflare? Do all 1" MC's have hard line connections in the same spots?
Old Mar 20, 2006 | 02:11 PM
cheehee's Avatar
Default Re: (cheehee)
anyone know which 1" MC/BB combo bolts up to an EK without bending lines?
Old Mar 20, 2006 | 02:20 PM
JDMFreak's Avatar
i currently have 98-01 ITR MC/BB and it will bolt up without re-flaring the lines it is a direct bolt on, well it was too big i had to take the intake manifold off to put on the MC/BB. good luck bro i hope this helps
Old Mar 20, 2006 | 02:34 PM
cheehee's Avatar
Default Re: (JDMFreak)
yea thanks for the help. I hope I don't have to take off my intake mani to do the install
I must have a 1" MC/BB from a DA because I know my lines won't bolt up.
Old Mar 20, 2006 | 03:24 PM
JDMFreak's Avatar
dont you mean DC? because from what i read on H-T, only the ITR will line up to our model without re-flaring the lines. anyway, like i said it worked for me and it will for you as well
as for the feel, it is not rock hard at all...it feel firm and strong, but if you slam on your brake pedal i guess it will be rock hard at that point...
Old Mar 20, 2006 | 03:27 PM
some you have to reflare, some you dont
see my how-to in the helpful faq link at the top of the forum
tells you how to do it and includes a link to reflaring
builtboostedteg
Jan 19, 2006 08:43 AM
Leb_CRX
Jan 31, 2005 08:40 PM
riceisnicenv
15
Aug 13, 2004 09:54 AM
B HATCH
11
Apr 15, 2004 05:07 PM
bruvaman
Jul 9, 2002 07:19 PM
