Trouble tuning LSVTEC
Old Mar 20, 2006 | 07:35 AM
TwinOptiX's Avatar
Default Trouble tuning LSVTEC
My setup:
95 B18B1 block
USDM P72 teg type r pistons
GSR head (stock)
gsr injectors
AEM intake
DC 4 to 1 header
test pipe
2.25" cat back
B&M adj. fuel pressure regulator
Walbro 190lph fuel pump
I'm using Crome 1.1.8R2, Moates Ostrich on a chipped P28. Fuel pressure is at 45psi w/ vacuum.
Before I put the fuel pump in the car was running very lean at part throttle and full throttle. I dyno'd thhe car at a local shop and was upset by the results. Not the Hp numbers but the A/F's. By very lean I mean A/F's between 13.75 to 18!!!!
I haven't been able to use a wideband since that dyno session but I've been trying to do the spark plug check to tune the car. I upgraded the fuel pump and still have weird problems. Here is a pic of the #1 cyl plug...
After 10K miles on the motor I have misfiring at idle and if I WOT at low mph and high gear (i.e. 4th gear at 20mph) the car bucks. I live in IL and on cold start on a cold day the car starts then bogs and dies. I have to hold the gas pedal down to keep the car running for the first minute.
Any suggestions?
Old Mar 20, 2006 | 10:13 AM
TwinOptiX's Avatar
BUMP....
Would a copy of my bin file be of any help?
Old Mar 20, 2006 | 10:57 AM
tgreaves's Avatar
Default Re: Trouble tuning LSVTEC (TwinOptiX)
Get a better pic of the plug for us.. And your saying that after it was tuned it was that bad of an air/fuel ratio?
Old Mar 20, 2006 | 12:30 PM
TwinOptiX's Avatar
I tried to tune the car on a dyno with wideband and the car just wouldn't richen up enough to get the ratio down. I believed it was because of the stock CX fuel pump. The best I could get was an unstable 14.7 to 15.9.
After that day I put in a Walbro 190lph.
I'll post a better pic of the spark plug tonight.
Old Mar 20, 2006 | 01:25 PM
TwinOptiX's Avatar
Here is a few more pics of the spark plug.
I know that the pics are still blurry but it's the best I can do with my shitty sony digital.
jdmdood333
14
Aug 27, 2012 12:02 PM
clemsoncb7
Dec 22, 2006 08:32 PM
Spins
Apr 13, 2005 04:12 AM
hondaeg8
12
Oct 15, 2004 06:25 AM
honda9369
Sep 22, 2004 02:44 PM
