*************PARTING OUT 2 Integras (GSR/LS) FS/WTT ***************
<U>ALL PRICES ARE OBO</U>
Located in Northern Chicago suburbs
I have pictures of a lot of this stuff so let me know
The doors and hatch and sunroof are in another FS thread
http://hondamarketplace.com/zerothread?id=1564520 <-- go there to see them
Call me if you have any question or if I'm not online and you want to make an offer on something.
(847) 533-2932
SOLD:
Seats
LS motor
<U>GOT PICTURES OF EVERYTHING LISTED BELOW</U>
<U>---Interior</U>
Brake and gas pedel assemblies
AC evaporator
Behind the dash ducting
Steering colum compete with key and selectors
GSR fuel pump
Truck Lid
Spare tire lid
Left rear interior 1/4 pannel
Right rear interior 1/4 pannel
Speeker covers
Under dash panels
Center console foam
Roof panel
<U>--- Electrical</U>
SRS Control unit
ABS Control unit
Main fuse panel
Engine fuse panel
Cruse control
All the relays
Main harness of the car (this is the one that connects everything together, it connect to the ecu and the dash and the fuse pannels and goes into the engine bay)
Drivers side harness
Passenger side harness
<U>--- Exterior</U>
Complete power steering rack
Fuel filter
Gas tank
Rear sway bar with brackets
Window wiper motor
Sway bar (front and rear)
Power steering pump
AC Compressor
Subframe
Brake Master cycliner with proportioning valve
Side skirts
Dash Board
Engine bay Brake lines perfect condition
Gas tank door
Windsheild wipper canister with pump motors
Strut bar
Sub frame brace
JUST ADDED
Rear triling arms assemblies
Front knuckle assemblies
Clutch pedel (with sensor)
Brake and Gas pedels
CLEAN ** Visors
Complete Steering Rack (left side)
Complete Steering Rack (right side)
Subframe Brace
Front sway bar
Windshield Wipper Assembly
Blower Motor and housing with all electonics and sensors
Subframe (without mount)
AC evaporator
Master Brake Boster with portoring valve
Steering colum with electonics and KEY
GSR fuel Pump
GSR Rear swaybar with brakets
Windshield wipper fluid container with motors
Spare cover
Drivers side interior 1/4 panel
Passenger Side interior 1/4 panel
All the different caps and plastic covers
All the different electronics
Clutch master cyclinder and reservor
Behind dash framing
Fuel something (forgot what it is)
Center console foam (only 1 of 100 still in existance unbroken)
Main car harness (left side)
Main car harness (center)
Main car harness (right side)
Left side engine bay harness
Carpet (no cuts or tears)
Roof linear
Deck lid
Dash board
GSR brake lines uncut unbent unsensored
GSR Right knuckle assembly (sold with everything in the pictures less axles)
GSR Left knucle assembly (sold with everything in the pictures less axles)
GSR Left trailing assembly (sold with everything in the picture)
GSR Right trailing assembly (sold with everything in the picture)
Just a glimpse of what my garage looks like
Modified by natesgarage at 9:57 AM 4/21/2006
(847) 533-2932
SOLD:
Seats
LS motor
<U>---Interior</U>
AC evaporator
GSR fuel pump
Truck Lid
Spare tire lid
Speeker covers
Under dash panels
Center console foam
Roof panel
SRS Control unit
ABS Control unit
Main fuse panel
Engine fuse panel
Cruse control
All the relays
<U>--- Exterior</U>
Fuel filter
Gas tank
Window wiper motor
Power steering pump
AC Compressor
Subframe
Side skirts
Dash Board
Gas tank door
Strut bar
Sub frame brace
JUST ADDED
CLEAN ** Visors
Subframe Brace
Front sway bar
AC evaporator
GSR fuel Pump
Spare cover
Behind dash framing
Roof linear
Deck lid
Dash board
I need a colant reservor, and any cool aftermarket **** you guys might have for an integra LMK
do you still have the hatch/trunk lid? and do you have the stock shifter from either car because my short shifter isn't working with my exhaust
