newbee.. need alot of help and advise..
Old Mar 19, 2006 | 07:51 PM
juanb's Avatar
Default newbee.. need alot of help and advise..
well im new to welding.. i just purchased a dual mig 151 welder from harbor freight..
these welds are done on the settings max1.. speed of 5.. (range from 0-10) with mig wire and the argon/co2 mixture..
im trying to do half moons and then full circles on some.. please dont be too mean, this is my first attempt to this.. any advise is GREATLY appreciated..
Old Mar 19, 2006 | 08:06 PM
8mpg's Avatar
well your last weld is showing improvement. I think you are trying to move way to fast on the other welds. Not seeing any penetratio non the pipe so that leads me to believe you are going to fast and dont have enough voltage. Turn up the voltage a bit. You want to see a slight ring around the welds and that willgive you an idea if you are penetrating or not.
any pics of the inside of the pipe on a weld?
Old Mar 19, 2006 | 08:27 PM
juanb's Avatar
Default Re: (8mpg)
here are some more welds...
these are from earlier today.. basicaly just draggin it along..
this is the inside penatration..
Old Mar 20, 2006 | 03:35 AM
2point2's Avatar
Default Re: (juanb)
try heat up, wire speed down. <-- take it from a fellow armature.
it looks like your rushing to compensate for a wire speed that is too high?
Old Mar 20, 2006 | 12:32 PM
Importordomestic's Avatar
Default Re: (2point2)
I agree
Old Mar 20, 2006 | 12:37 PM
david@didrace.com's Avatar
Default Re: newbee.. need alot of help and advise.. (juanb)
Try doing stringer beads (straight lines), not really any reason to do anything but on a flat piece of metal.
Old Mar 20, 2006 | 02:57 PM
juanb's Avatar
Default Re: newbee.. need alot of help and advise.. (backpurge)
well i was practicing today.. this is with the same heat..
this is with the heat hotter... it just seems like it wants to blow right through it..
Old Mar 21, 2006 | 11:10 PM
supercreed2002's Avatar
I'm also in the learning stage and one thing I've learned is set the heat on a higher setting and slow the wire down so you you get a slight bump. you wanna move the gun slow on the linear movment, but try doing medium pace circles until you get something like this:
Old Mar 22, 2006 | 07:58 AM
LBHgti's Avatar
Default Re: newbee.. need alot of help and advise.. (supercreed2002)
Not half bad.......for a NEWB
Seriously, those look great for your second day of welding. I started off with a HF fluxcore welder, and it taught me a lot...wasn't a bad machine either. Your new MIG has definate potential. Just keep practicing until you are happy with your welds. The number one problem that new welders have is that they cannot see the puddle. Most of the cheapo helmets/sheilds are two dark and all you can really see is a bright flash. If you can position yourself and get the correct shade lense so that you can see the puddle pretty well, your welds will come out beautifully. keep it up, you're doing good.
Old Mar 22, 2006 | 08:57 AM
fabnewb's Avatar
Default Re: newbee.. need alot of help and advise.. (LBHgti)
the best advice i can giev to any new mig welder is to use "BOTH" hands to keep teh gun stable.
Old Mar 23, 2006 | 02:22 PM
VRD^don's Avatar
Default Re: newbee.. need alot of help and advise.. (fabnewb)
play with it and mess around with the settings. see what suits you.slow down on your welds.....
Old Mar 26, 2006 | 04:05 PM
deryck324's Avatar
try sitting down and steadying your arms on the edge of the table that helped me out alot
Old Mar 26, 2006 | 05:52 PM
Default Re: (deryck324)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deryck324 &raquo;</TD></TR><TR><TD CLASS="quote">try sitting down and steadying your arms on the edge of the table that helped me out alot</TD></TR></TABLE>
yea, I don't have a table but I put my stuff on a little stool, squat down a little bit, and rest my elbows on my legs....works great, except for last time, the welds didn't come out too good(maybe welding 2 in the morning doesn't much).
acuraocd
Apr 17, 2008 08:04 PM
shanaou
Dec 26, 2007 05:54 AM
CBURKE
Welding / Fabrication
60
Aug 13, 2007 12:02 PM
AdamB18C1EK
Feb 7, 2007 03:40 AM
BlackEG6
Jul 13, 2006 06:54 AM
