checked 2 other ek civics....wtf does this go to
Old Mar 19, 2006 | 06:41 PM
93b18civic's Avatar
Default checked 2 other ek civics....wtf does this go to
i have a 99 ex coupe and i looked at a 96 and a 98. my 99 has an extra sensor on the thermostat housing that the other 2 dont have. and it tee's off and where it tee's there is a vacuum line that goes to nothing. if i plug it there is a LOT of vacuum and the car idles down a bunch. but i have looked everywhere and i cant find anything to attatch it to. heres pix
ANOTHER VIEW
someone please lmk. thanks
Old Mar 20, 2006 | 07:10 AM
egsleepercivic's Avatar
in 99 civics changed to obd2b the 96 and 98 were obd2a check a 99 or 00 civic it should help you... I would guess that it has something to do with the change from obd2a to 2b good luck
Old Mar 20, 2006 | 04:44 PM
93b18civic's Avatar
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">in 99 civics changed to obd2b the 96 and 98 were obd2a check a 99 or 00 civic it should help you... I would guess that it has something to do with the change from obd2a to 2b good luck</TD></TR></TABLE>
i appreciate your help but obd2a to obd2b is a wiring change. it has nothing to do with the vacuum lines. i found out that it goes onto the intake arm. but since i am using an intake arm off a car that doesnt have the nipple i need i got it under control with ordering a aem unit. thanks though
Old Mar 20, 2006 | 07:21 PM
MotorMouth's Avatar
Default Re: (93b18civic)
EGR line to evap cannister, it would be mounted to the firewall and that line provides vaccum to the cannister to vent the gas tank at idle.there should be a plug for the solenoid that regulates when it opens.
At least thats what I can tell from your pics.
Old Mar 21, 2006 | 06:43 AM
EE_Chris's Avatar
Default Re: (MotorMouth)
Kind of looks like the Air Injection unit that appeared on 99-00 Ex's. It just helps provide additional air at startup when the coolant is cold (is the bottom of it sitting in the thermostat housing?). If you've ever held a 96-98 and 99-00 Ex intake manifold, you'll notice 4 small holes on the inside the 99-00 manifold flange above the intake ports. Those holes lead to that valve and the other hose that isn't connected (from that valve) should be connected to the intake piping.
Part #24?
Old Mar 21, 2006 | 09:46 AM
93b18civic's Avatar
Default Re: (EE_Chris)
BINGO
that is the one.
i have one question. where do you guys get these diagrams from? i see them posted all the time. please lmk.
i used to own eg's forever and i didnt need the diagrams cause i knew the car better than my own nuts, but now i have a 99 and there is a lot different. lmk please. thanks
Old Mar 21, 2006 | 10:15 AM
EE_Chris's Avatar
San Leandro Honda
Old Mar 21, 2006 | 04:52 PM
93b18civic's Avatar
awesome. thanks
Old Mar 21, 2006 | 07:02 PM
MotorMouth's Avatar
learn something new everyday
butlerej8
Jun 15, 2015 05:07 PM
93b18civic
Mar 20, 2006 12:22 PM
Odiedogcx
Mar 17, 2006 11:37 AM
S2KILLA
Jan 31, 2005 07:02 PM
jdmfun99
Jun 6, 2004 10:42 PM
