Suspension & Brakes Theory, alignment, spring rates....
Front end shake under power.
Old Mar 19, 2006 | 10:08 AM
Stoich's Avatar
Default Front end shake under power.
Everytime i hit a bump under power the car kinda shakes and hops . Its kinda of annoying any ideas?
Suspension
GC sleeves on Koni yellows
New LCa bushings all around
New oem UCAs
Old Mar 19, 2006 | 03:43 PM
mahatma's Avatar
Default Re: Front end shake under power. (Stoich)
Engine or tranny mount possibly?
Old Mar 19, 2006 | 04:44 PM
Stoich's Avatar
Default Re: Front end shake under power. (mahatma)
Hasport Mounts so prolly not
Old Mar 19, 2006 | 10:32 PM
chrisw85's Avatar
you have an open diff? but i dont know if this has to do with it.
Old Mar 20, 2006 | 06:51 AM
Stoich's Avatar
Default Re: (chrisw85)
Na i have the stock lsd trans
Old Mar 20, 2006 | 07:16 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">GC sleeves on Koni yellows
Hasport Mounts</TD></TR></TABLE>
If those new bushings are Poly, you're running a pretty stiff setup. Could be normal; I know my car hopped on the street alot with my GCs.
Old Mar 20, 2006 | 07:19 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Stoich)
I have heard that a bad inner CV joints will cause a shimmy in the front end when power applied. I doubt that has much to with bumps & instability, but it couldn't hurt to check...
Also, make sure your rear Trailing-Arm bushings are in good shape. When these oversized bushings go bad, it creates an unstable feeling in the car over uneven surfaces...
Old Mar 20, 2006 | 10:52 AM
Stoich's Avatar
Default Re: (94eg!)
All the bushings are OEM honda.
Old Mar 20, 2006 | 11:34 AM
msmotorsports's Avatar
Its your wheels unloading. This is similar to the tire shake you see on Top fuel cars. This really shocks the tranny/axles, so I would suggest to pedal over bumps or whenever your tires feel like they are unloading.
Old Mar 21, 2006 | 04:47 AM
Stoich's Avatar
Default Re: Front end shake under power. (msmotorsports)
Is there any way to get rid of this? Im on my snow tires right now.
Old Mar 21, 2006 | 07:31 AM
traction bars may help if you don't already have them. Other than that just take it easy over the unsmooth sufaces. This is just one of the disadvantages FWD cars experience over RWD.
Old Mar 21, 2006 | 01:00 PM
Stoich's Avatar
Yeah I have Full race traction bars. Oh well
katzenjammer84
Suspension & Brakes
Jun 11, 2008 07:05 PM
GuCCi_GSR
Jun 7, 2007 04:02 PM
SCIVIC94
12
Mar 3, 2005 02:31 AM
JeremyL
20
May 14, 2003 07:36 PM
